1998 honda civic wire short
Old Nov 16, 2015
Xplosive1687's Avatar
Xplosive1687 is an unknown quantity at this point
I believe I have a short or loose wire somewhere.
I bought the car with this issue beliving it to just be fuses. Inatrument panel is not entirely lit up. Generallt lights up to 100mph after that its dark. No lights around parking and sometimes no lights around fuel and tempature. Also no lights around most of the heater switch except the defroster button. Somedays the lights start dim then light up the whole speedometer. i changed the dimmer switch no change. Changed some fuses for good measure, nothing. What makes me believe this is a potential loose wire is I hit a bump one night and saw the light around my tempature and gas gauge come on. Is this some kind of short? Also The driver side front speaker and tweeter dont work. Tried to put a sony 3 way speaker in there but didnt do anything so its empty right now. I do hear sound coming from passenger side tweeter but every so often I hear the driver side tweeter cut on briefly. Radio station cuts out and goes to static where I can hear a slight whine. Previous owner had a aftermarket deck in car but the wiring harness seemed rigged. There was speaker wire running from the yellow wires to some kind of plug like it was jumped. Unhooked those wires but could that be thd culprit? Thank you all !
Old Nov 16, 2015
Re: 1998 honda civic wire short
Think about how old all those 18 year old light bulbs are by now.....
Ohm check each wire between radio and speaker. Those cars like to break the wires in the door jamb where they flex.
Check antenna connection in back of radio.
Old Nov 18, 2015
Should I replace bulbs in the cluster and in the heater panel? I'm not sure exactly why kind of bulbs to get I saw a lot of different ones for the cluster. I was going to look at the harness again behind the radio for the antenna connection just to make sure. How do I do a ohm check? Multimeter?
Old Nov 18, 2015
Bulbs are certainly cheaper and easier than chasing other stuff.
Check speaker wires as described earlier while you're in there.
Absolutely.
Google. Youtube.
You can check each light bulb with the same meter.
Find the bad ones, then take them to the store and match them up if possible.
Consider replacing every bulb you can get your fingers on just because they are ALL that old.
HTH
Kyle Cargazm
Jul 4, 2015 05:32 PM
sdraza1
Jul 2, 2015 06:04 PM
roger t
Jun 22, 2015 07:25 PM
nufc
Legal Questions and the Law
Jun 21, 2015 09:57 PM
2HondaCivics
Jun 19, 2015 12:06 PM
