DRL Nasty sound
Old Apr 4, 2013
George91's Avatar
Steel City Youngin'
George91 is an unknown quantity at this point
DRL Nasty sound
Hey all, I've recently had the time to look into a nasty sound that was coming from behind the glove box in my 03 civic. I found the source, just don't know how to go about fixing it. I made a video of it, tell me what you think.
****The sound goes away as soon as I switch on my lights****
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1394& transactionid=1365112375-20721038205&posted_by=_www.civicforums.com&youtube _video_id=EjNzQyF2nNo[/autostream]
Old Apr 4, 2013
CraigW's Avatar
Re: DRL Nasty sound
https://www.civicforums.com/forums/3...ng-ebrake.html
Find the DRL control unit and resolder the relay pins on the PCB.
Old Apr 5, 2013
George91's Avatar
Steel City Youngin'
Re: DRL Nasty sound
Fixed, thank you very much.
Old Apr 12, 2013
George91's Avatar
Steel City Youngin'
Re: DRL Nasty sound
Ok it's only been a week since fix, and I've noticed my right head light won't turn on for lo-beams, DRL works for both lights, as does hi-beams, but lo-beams only left side works. Could this be because of the solder, or is it just the lights gone bad?
Old Apr 13, 2013
CraigW's Avatar
Re: DRL Nasty sound
Check the bulb, I dont think the low beams tie into drl control unit.
Old Apr 13, 2013
hioto's Avatar
hioto is an unknown quantity at this point
Re: DRL Nasty sound
Check the bulb first but im sure they do tie in through the DRL module. You may need to replace it.
Especially if the bulb was fine before the fix.
http://torontohondaparts.com/Part.as...=38260-SM4-C03
Old Apr 14, 2013
CraigW's Avatar
Re: DRL Nasty sound
https://www.civicforums.com/forums/a...4&d=1232212860
https://www.civicforums.com/forums/a...3&d=1232212860
Have a look.
Check the bulb.
Old Apr 16, 2013
George91's Avatar
Steel City Youngin'
Re: DRL Nasty sound
Took a look at your diagrams, doesn't seem like the under dash relay has anything to do with low beams. Honda Electrical manual 01-03 models W_DRL2 of 2.pdf if you follow line C9 down it goes to the right headlight. I haven't had the time to check the bulb, will post as soon as I can.
Old Apr 16, 2013
hioto's Avatar
Re: DRL Nasty sound
A faulty DRL module will sometimes cause the relay behind the glovebox to buzz.
But as stated above, check the bulb first
Old Apr 18, 2013
George91's Avatar
Steel City Youngin'
Re: DRL Nasty sound
So It was just the bulb after all, recently went ahead and installed a 8000k HID kit, and they're shining with all their glory. Thanks again for the help.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
2005seTO
Aug 18, 2015 12:45 PM
CraigW
Aug 18, 2015 07:06 AM
BootyDo
Jul 26, 2015 10:38 AM
Hqly2001
Jul 25, 2015 05:32 PM
