02 EP3 buzzing noise from steering column after Disengaging EBrake
Rep Power: 0 02 EP3 buzzing noise from steering column after Disengaging EBrake
I have a buzzing noise starting after i turn on the car. It won't start until i put my E-Brake down. Once i disengage my E-Brake it starts buzzing from the steering column or gauge cluster. To get it to stop i have to turn on my Headlights. I am about to put in some HID's and I would rather not have to burn the bulbs during the day. Any help would be greatly appreciated
Re: 02 EP3 buzzing noise from steering column after Disengaging EBrake
Ya its the DRL module. Use that link above. I have a question about which solder to use on the circuit board? I bought clear flux solder. Will that work right or do I buy a different kind ?
Rep Power: 0 Re: 02 EP3 buzzing noise from steering column after Disengaging EBrake
thanks guy's. I won't have a vehicle inspection anytime soon so i have just removed the module for the meantime. I will get to soddering it and put it back in when i get a chance but for now i don't really need DRL's.
Agreed. Use 60/40 rosin core solder and get one of these: to remove the old solder so you can make a clean new connection.
Well then i Think i bought the right stuff. Here is what I bought if anyone wants to verify before I get someone to solder it. Thanks
http://www.thesource.ca/estore/produ...roduct=6400018
In case mine can't be fixed for whatever reason I might just replace the module. I was given the part number 38260-SM4-C03. Is that correct ? Not sure if that's the relay or the module. Thanks
06Si_Girl
07-12-2015 12:08 PM
igorbogu
07-10-2015 09:29 PM
1khilari
07-09-2015 08:12 PM
