Horrible, LOUD buzzing from tires or wheel bearing?
Old Apr 4, 2013
Neutrino's Avatar
Neutrino is an unknown quantity at this point
I have a 2001 Civic LX which I just had shod with new Michelin Defender tires all around. Now it sounds like I have off-road knobbies instead. WTF? It increases in pitch with more speed; becomes loud at about 25 MPH, and terribly loud at 60.
I've been told that this could be failing wheel bearings. I also learned that the right front bearing is not too healthy and the CV boot has a tear in it.
The sound, though, sounds like it's coming from both sides (I can't tell if it's also from behind).
BTW, Costco replaced the first set, but that made no difference; set 2 is just as loud.
What do y'all think? The previous tires were not nearly as loud, and I doubt that Costco replaced the bearings with bad ones when they fit the new rubber. Could bad or failing bearings actually make such a gawd-awful noise? Is it likely to be bad tires or a bad bearing? These are supposed to be quiet tires, for pete's sake.
Thank you in advance for your wisdom and/or input.
Old Apr 4, 2013
BlueEM2's Avatar
Whachya lookin at?
Re: Horrible, LOUD buzzing from tires or wheel bearing?
Probably the bearings... They can get rather loud when failing.
Old Apr 4, 2013
Neutrino's Avatar
Wow. I don't understand how that works, bearings sounding like knobbies, but okay.
If it has been making this sound for near-ish 3000 miles, will I likely need to get the hub and/or axle replaced as well?
Old Apr 4, 2013
killaclownne1's Avatar
killaclownne1 is an unknown quantity at this point
Does it quiet when turning a corner? That gives you an idea which bearing is going. Is the sound coming from the front?
Old Apr 4, 2013
Neutrino's Avatar
Yes, definitely from the front.
Corners don't seem to matter, but I'll keep a closer ear on that.
Old Apr 4, 2013
My front driver bearing is gone. So going slow it isnt as loud but the faster you go the louder it is. when i go around a bend that goes left its quiet if i go the other direction it doesnt change.
Old Apr 4, 2013
BlueEM2's Avatar
Whachya lookin at?
The bearing has no indication of what the hub + axle look like. Most likely you will need just the bearing replaced. If you do replace it get an OEM, National, or Timken bearing. Anything else won't last long.
Old Apr 5, 2013
Neutrino's Avatar
I would love to do this myself, but currently lack any kind of garage space and a press. sigh
One mechanic told me that a failing bearing can wreck the hub if left too long (especially if, as in my case, there is a small tear in the CV boot). A couple have told me that a failing bearing means the axle must be replaced as well. What gives? Are these particular shops just out for more work/money? (It seems to me that a generic rule of 'we replace the axle every time we replace a bearing' is kinda lame.)
Thanks for the heads-up on bearing manufacturers - I'll keep that in mind.
Old Apr 5, 2013
mikey1's Avatar
if its a humming or buzzing noise that is consistent with the speed of the vehicle it sounds like a bearing, i had one go on mine, get it looked after ASAP, a bad wheel bearing can be very dangerous if it lets go
Old Apr 5, 2013
BlueEM2's Avatar
Whachya lookin at?
If you remove the knuckle yourself you can usually find a shop willing to press it for 20 bucks. It quickly turns 200 dollars labor into 20 dollars. I did mine in my driveway.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bsmiley
Apr 27, 2015 01:27 PM
bo_red
Apr 23, 2015 10:09 PM
VNlilMAN
Dec 6, 2001 01:25 AM
