fog light issue that others may be having
Old May 28, 2008
slammedcivic85's Avatar
Member
slammedcivic85 is an unknown quantity at this point
ok i wired my fog lights today got it all up and running my only concern is that the back light stays on when the car is powered off the key is out of the ignition the car is lock and so on... when i say the back light i mean the light that is on the front of the switch not the one that lights up when you press the button to turn the fogs on... is anyone else having this problem and if so how can i fix it???
Old May 28, 2008
TRIZ's Avatar
Re: fog light issue that others may be having
Ummm, confusing- picture?
Old Jun 6, 2008
PaCiFiKbAllA's Avatar
PaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond repute
hes talkin about the fog light button inside the car...somethin aint right...i'd check the wires or replace the switch...
Old Jun 6, 2008
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
sounds like you have them wired to a constant 12V source. splice the power into a switched 12V source and your problem will be solved
Exterior
Nov 28, 2025 05:23 PM
LuvMyCivic
Dec 12, 2001 10:02 PM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
WhosYoDadday85
Nov 11, 2001 05:41 PM
