which wire controls milage
Old Feb 13, 2007
civic05acer's Avatar
civic05acer has a spectacular aura aboutcivic05acer has a spectacular aura aboutcivic05acer has a spectacular aura about
just wondering which of the guage cluster wires controls the odometer. and is there anyway of disabling it. any help is appreciated.
GREEN Connector:
Blue: From ECM/PCM, Tach input signal
White/Red: Constant 12 v +
Yellow: Switched 12V+
Blue/White: From ECM/PCM And VSS input signal
Yellow/Black: From fuel level sending unit
White/Green: From multiplex control unit
Black: Ground
Pink: (Canada Vehicles only) Washer fluid level switch
White/Blue: (Canada Vehicles only) DRL Control unit
Black/Yellow: Security control unit
Blue/Yellow: Cruise control unit
Pink/Blue: OPDS unit (Side airbags)
BLUE Connector:
Black: Ground
green/orange: From ECM/PCM
Blue/Red: From ABS Control unit
Pink: From SRS unit
Red/Black: Supplies 12V+ for dash backlights
Red: Supplies switched ground for dash lights
Green/Red: Left turn signal indicator
Green/Yellow: Right turn signal indicator
Red/Blue: Combination light switch
Blue/Orange: Immobilizer control unit
Red/Yellow: From no 15 fuse under hood
White/Red: From no 9 fuse under hood
Yellow/Red: From oil pres switch
Old Feb 13, 2007
01HonderCivic's Avatar
Don't be a n00b, search ftw
Blue/white: Vehicle Speed Sensor Input Signal
Old Feb 13, 2007
sweet if this work rep. do you know if all the other things on the cluster will work
Old Feb 13, 2007
I'm not sure. I know if I were an auto manufacturer trying to prevent odometer fraud, I'd put in some type of setting so that if there's not power coming in from the VSS wire, then nothing on the cluster would work. I don't know if this is how it actually is, but there's only one way to find out...
Old Feb 17, 2007
just wondering isnt there a way that dealerships check you mialage and see if it matches your cluster. i was told that by someone but isnt out milage tracked on our cluster.
Old Feb 17, 2007
Yeah, I'm fairly certain that it's only stored in our clusters
Old Feb 17, 2007
Bad_Civc's Avatar
If Your Reading This Your Dee Dee Dee
Bad_Civc is an unknown quantity at this point
ya but you can go for 3 months on a car and only put 100 miles on it ...
most dealerships only pay attention to the cluster anyways... they arent going to plug up anything and look for mileage anywhere else
Old Feb 17, 2007
ok well an update on this. i took the blue/white wire off and the odometer did stop reading the miles. the catch is the mph is not workin so yea. oh yea and + one rep 01honciv
Old Feb 17, 2007
Yeah....The ECU can't read MPH when the Vehicle Speed Sensor is disconnected
Repped back
Old Feb 17, 2007
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
you do know that is illegal right?
Old Feb 18, 2007
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
yes.. a sick, bald bird
illegal...get it? ok.... nvm
ya, why do you want to stop it anyways? just drive it and be happy with it
Old Feb 18, 2007
zen_master's Avatar
i though that having such discussion in this forum is illegal in the first place.
Old Feb 18, 2007
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
why didnt you just unplud the vss at the trans? it will catch up with you one day. mileage is recorded at every oil change place, dealership, and anywhere else they ask your mileage. carfax will tell all. it will show your car went a year or some **** with no mileage change? its people like you that make buying used cars a pain in the ***.
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
usajags84
15
Aug 19, 2015 03:12 AM
WaryDriver
23
Jul 22, 2015 07:18 PM
MamaBear2015
May 18, 2015 07:37 PM
LuvMyCivic
Dec 12, 2001 10:02 PM
