Two hondas
Old Apr 6, 2019
Chbronco's Avatar
Chbronco is an unknown quantity at this point
Two hondas
Have a 2002 Honda sedan lx with 260k km,bought a 2005 Honda sedan se with 230k km for the daughter. Her car seems to have more power fair amount more.,both are manuals. Why both have the same motors?Wouldn't bother me much if mine was the faster one lol.
Old Apr 6, 2019
Colin42's Avatar
Re: Two hondas
Tranny may have been swapped, I did that with my gold car, the VTEC trans has shorter gears to make it sportier/faster
Brakes could be dragging,
Old Apr 6, 2019
Re: Two hondas
or you need to do an engine tune-up
Old Apr 6, 2019
Slumpertcivic's Avatar
Re: Two hondas
Maybe your catalytic converter is more plugged up..
Are you sure she she doesn’t have any speed stickers on her car, those make a real difference especially when your have 4 or more.
Seriously though, fouled plugs, clogged cat, clogged air filter, dragging brakes all can make a noticeable performance drop.
Old Apr 6, 2019
rogerscivic's Avatar
rogerscivic is an unknown quantity at this point
Re: Two hondas
talking about brakes i once had a ford ranger that dragged the front brakes it did feel more slugish, and smelled horibly after parked in the garage thats a possibility on chbronco
Old Apr 6, 2019
Chbronco's Avatar
Re: Two hondas
Well both bought used so dought of the Trent swap.if the cat was pluged or restricting would it not show up with dash lights..runs smooth would plugs make that much diff? Will check plugs and air filter
Old Apr 6, 2019
Re: Two hondas
Timing belt off by a tooth can reduce power quite a bit.......
Old Apr 7, 2019
Chbronco's Avatar
Re: Two hondas
I know this doesn't mean much but the previous owner is BMW shop mechanic that did the belt clutch mataince. Runs smooth starts good but seems flat has mor pep in the upper rpm .when shifting motor sure won't lug must shift.
Old Apr 7, 2019
Re: Two hondas
https://www.civicforums.com/forums/1...e-up-mods.html
Old Apr 8, 2019
Chbronco's Avatar
Re: Two hondas
What are the pros and cons of removing the cat.
Old Apr 8, 2019
Colin42's Avatar
Re: Two hondas
pros: none, car was designed to have it. it's not a restriction like they used to be back in the day
cons: illegal pretty much everywhere, check engine light will be on, fuel mileage usually decreases, bad for the environment, exhaust will stink with no cat, etc
Old Apr 8, 2019
Chbronco's Avatar
Re: Two hondas
Should I try the lacquer thinner cat cleaning method?
Old Apr 8, 2019
Colin42's Avatar
Re: Two hondas
you can try, probably won't work.
if you don't want to buy the expensive cat, the cheapo will last about a year
Old Apr 8, 2019
Chbronco's Avatar
Re: Two hondas
Anybody here try Mr gasket catacleaner has good reveiws? $60 CDNshould work.
Old Apr 8, 2019
Colin42's Avatar
Re: Two hondas
I used a similar product I got at canadian tire in my gold car. It had an intermittent P0420 code.
It worked for at least 30,000kms, but then the car got written off
Old Apr 8, 2019
Chbronco's Avatar
Re: Two hondas
Collin did you notice any performance increase?
Old Apr 8, 2019
Colin42's Avatar
Re: Two hondas
nope, but the check engine stayed off.
quick check to see if the cat is clogged would be to remove the primary o2 sensor and take it for a drive. see if it performs better
Old Apr 8, 2019
Chbronco's Avatar
Re: Two hondas
Ok thanks
Old Apr 13, 2019
Chbronco's Avatar
Re: Two hondas
Changed the air filter good amount of difference, it's a 2002 lx would a new oxygen sencer make a diff.
Old Apr 15, 2019
Chbronco's Avatar
Re: Two hondas
So I guess if I don't have any lights on the dash my sensor is good?car has 250000km a new one would not help performance?
Old Apr 15, 2019
Colin42's Avatar
Re: Two hondas
performance? no, mileage maybe a bit.
get a scanner that does live data and you can watch the voltage swing back and forth, a new sensor will sweep quickly, an older one will be slow
Old Apr 15, 2019
Re: Two hondas
Many low cost scanners don't update displayed data quick enough to actually judge the speed of an active primary O2 sensor. JMPO.
Not always.
Old Apr 15, 2019
Colin42's Avatar
Re: Two hondas
Valid point
Old Apr 15, 2019
Chbronco's Avatar
Re: Two hondas
Thought there was hp sensor, but not for the lx just the ex ike I said new air cleaner made a good diff going to change the spark plugs,what else?
theteju
Oct 21, 2017 11:05 PM
chaz_so_239
Apr 20, 2013 06:28 PM
DALMO
Feb 11, 2013 08:04 AM
LilGripper
Apr 21, 2012 07:49 PM
SlowStockCivic
15
May 16, 2006 12:12 PM
