Y8 Engine removal
Old Apr 20, 2013
chaz_so_239's Avatar
chaz_so_239 is an unknown quantity at this point
Y8 Engine removal
Anybody know the steps to taking out the engine from the tranny I have everything unbolted but need help getting the torque converter off so I can slide the engine off from the tranny
Old Apr 20, 2013
Re: Y8 Engine removal
About 8 bolts, all 10mm heads. Once all are removed, the converter can spin independently of the flex plate. It may push back a few millimeters, that's it.
You have to pull the engine and trans straight apart until the snout of the converter is free from its bushing (maybe 1/2 inch?), or else it will be stuck tight by that bushing and try to pull the converter out of the trans.
If you can't, then you have to wiggle engine/trans while prying the converter away from the flex plate until completely released and free.
Do not dent the converter.
Old Apr 20, 2013
thanks im going to let you know how it goes if i have any more questions
CarStuff
Dec 6, 2020 12:52 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Dmitri
123
Oct 13, 2005 08:01 PM
Grey
16
Jan 27, 2002 11:34 PM
