View Poll Results: Will polishing the inside of an intake manifold improve performance?
Yes, it will improve performance
0%
No, it won’t do anything at all
100.00%
No, it will reduce performance
0%
Voters: 3. You may not vote on this poll
D17VTECPOWER threads consolidated - how a member should not behave
#1112
Received 1,461 Likes
Rep Power: 341 Re: Why aren’t bearings fastened down?
go see if these guys will get the answer for you
pointless to wonder why the car maker do or not do in a forum that do not have the engineer that designed it.
http://www.7thgenhonda.com/forum/index.php
https://honda-tech.com/
#1113
Rep Power: 341 Re: Should I upgrade my front sway bar? Poll
^ it was not clear on your response if you were recommending or not.
poly bushings are a lot of work for very small gains for most drivers.
#1115
If it melts or welds up and tries to lock itself to the spinning crankshaft, what happens?
If it happened at idle, it might shut the engine off and it's over.....but locking up at idle is as rare as hens teeth.
Whenever an engine destroys itself, 9 times out of 10 it's flying down the road one way or another. At speed, under load, when lube needs are the greatest.
Does that soft little bearing or a little hardened steel dowel pin have enough (strength) to bring all that spinning mass of a (4000+ RPM, 127 fire breathing horsepower) crankshaft, connecting rods, flywheel, clutch or converter, transmission, drivetrain, and complete car to a screeching halt?
Fk no. It's gonna rip something apart, whatever the weakest link is
Go back and reread the last line of the reply from RobertD again
#1116
Rep Power: 341 Re: 2005 Civic strut bar
https://www.clubcivic.com/forum/thre...talled.188613/
you can see the oil dip stick - use as visual reference. quick search in internet yields answers faster than asking
#1117
OK. Thank for the reply, D17vtecpower and sdaidoji.
I will definitely get a sway bar at the very least. I'm just curious to know, since it's the front suspension (Macphersons) in this generation that's to blame for the sub-par handling, how is it that a "remedy" is placed in the rear part of the car ?
BTW, isn't an anti-roll and anti-sway bar the same thing, or do they differ somehow?
#1118
yes, they are the same, but sway is the wrong word - it defines a different dynamic of the car, but is the most used term in US. just somebody decided that sway is the one, and the others followed. Like when people call the shocks in a double-wishbone suspension a strut - strut refers to structural shocks, which is not the case in a double wishbone suspension - you remove the shocks and the suspension still holds its geometry in a double wishbone suspension, so shocks are not "structural" to the system. Or calling the adjustable height suspension a coilover (a McPherson suspension without the ability to adjust height is still a coil over.)
a lot of car dynamics are related to balance. so changing one end of the car affects the other end. the MacPherson is the root of the issue, so to compensate for that, change the rear. It would not be easy to change the front to a double wishbone, i mean.
#1119
OK, sdaidoji. Thanks for the reply and the explanation. I find it really interesting how a fix applied to the rear suspension can actually affect how a car handles even though you'd think it's the front suspension that should be addressed. Physics and the weird way they work.
Also, people spelling it McPherson, when it's actually Macpherson strut.
#1120
Prelude Owner
No it doesn’t interfere with adding or checking oil. Google image search Neuspeed Strut Bar EM2 and check it out. When I had it installed I don’t remember it causing an issue.
#1122
Any body can recommend a brand that's quiet and not too pricey ?
#1123
Sure. I have Energy Suspension poly bushings in the front control arms, which helped a little. I also have Godspeed Traction-S lowering springs, which helped a lot. I also have Energy Suspension bushings on the stock front sway bar, and I have an RSX-S 21MM sway bar in the back, which made a large difference in handling. That's about it for now, but I will be getting poly bushings for the rear suspension, and I will also be getting a rear camber kit to correct the camber since I lowered it. I will probably also get a front strut bar soon. I will let you know what improvements I notice when I do those upgrades. If you have any questions, feel free to ask!
Do the Energy Suspension bushings help on the front sway bar? Are they hard to install ?
#1124
I noticed a small improvement in steering response, and they are cheap and easy to install. I think they were about $12, and they took about 20 minutes to install. However, my bushings were worn out, so the improvement was probably from new bushings more than the bushings being poly.
#1125
Thanks. Yeah I've read about this a few times already. I think the winter tires that I have on the car are contributing to the bad handling. They feel really hard (on the road) as if they were made of wood and they're too damn noisy too.
#1126
Received 1,169 Likes
Rep Power: 487 Re: 2005 Civic strut bar
Neuspeed bar sits damn near against the firewall. The one I sold had rub marks on the backside where it contacted the plastic hood cowling
You do have to bend the clutch fluid reservoir out of the way tho
#1127
#1128
#1130
Winter tires, especially crappy ones, will certainly ruin your handling. I'd suggest getting a nice set of tires before any suspension upgrades. I can't remember how wide you can go on stock 6 inch rims, but wider tires will help too. I had 225 tires on my 7 inch rims with no problems. I also found that my steering feels more precise and responsive running a few PSI more air in my tires too.
#1135
Rep Power: 341 Re: Strut bars?
I explained that on link above, where there are also multiple links to to other threads
#1136
Prelude Owner
This is actually my plan with my Fit possibly lol. Not for a strut tower because of the stupid cowl but maybe a rear sway. Its a solid rear beam but it would be fun to try even if it didn't help much.
Once I find a box I will PM you my PayPal info so you can send the money.
Yes that's right about the clutch resevoir but with a slushbox its ok
#1138
#1140
Prelude Owner
Do you still want a rear camber kit as well OP? I know you wanted poly bushings but I dont think they make rear camber arms with poly bushings do they?
