Should I use...
Should I use...
So on the trunk of my car there is a small rust spot, about the size of...well lets just say its small. About the size of this smile face -->
. My question is should I use touch up paint on it? I searched around and found some topics on touch up paint but only about how bad it looks for trying to fix a long scrape.
Thanks for any help.
. My question is should I use touch up paint on it? I searched around and found some topics on touch up paint but only about how bad it looks for trying to fix a long scrape.Thanks for any help.
Re: Should I use...
Sand it to the point there isnt any rust left, prime it, then use touch up paint. Sanding between coats of primer and paint is optional- do it if you you can ruff up the paint more so it has something to hold on to.
Re: Should I use...
Alright, Im defintely going to do that. Thanks TRIZ.
Anyone have any good experiences with touch paint? I know it will look better than a tiny rust spot, but just want to get some opinions.
Re: Should I use...
i recently used touchup paint all over my car. it wont match perfectly but it looks a ton better than rust. get some rust dissolver gel and use that to take the rust off. put a lil bit on and let it sit a minute or two but no longer. it wont hurt the surrounding paint. then wipe off excess gel and put touchup paint on. sanding is just gonna make a worse mess.
Civic15
Dec 4, 2013 09:24 AM
dem0nk1d
Dec 10, 2012 09:38 PM
Shadow
20
Aug 22, 2007 01:23 AM
AXIS
Jun 9, 2007 08:56 AM
