Fuel Pressure regulator !!! what are you using!!!
Old Jun 4, 2008
valenzuela's Avatar
valenzuela should not be trustedvalenzuela should not be trustedvalenzuela should not be trusted
are you putting the reg. before or after the the fuel rail?
if you could tell me what regulator your running?
and what regulator you would recommend ? im in the process of ordering the
parts.
i just got a spare fuel rail and -6an steel bung tig welded on it.
Now i have all the line and fittings i need .
and my plan is to dump the return line to th filler neck instead of the top of the fuel pump assembly. so i don't aerate the fuel
also i'm running 3/8" stainless steel tubing under the car instead of stainless steel braided line. for cost effective reasons.
This project is to run E85.
Old Jun 5, 2008
speedfoos's Avatar
Re: Fuel Pressure regulator !!! what are you using!!!
I will be running this FPR in about 3 weeks.
Aeromotive FPR (Summit P/N: AEI-13109)
As for the location of it, I'm putting mine after the rail. I think that's how it's supposed to go, but am not completely sure.
Old Jun 5, 2008
valenzuela's Avatar
since there is a inlet an outlet for fuel plus the return line how would you end up plumbing the line back to the tank.
Old Jun 7, 2008
speedfoos's Avatar
Line comes straight from pump to fuel rail. Return goes from other end of rail to the FPR (inlet) and then out to the tank (outlet) to drop back as the return.
mjdiaz89
Jun 21, 2016 09:26 PM
jzhartman
22
Jul 23, 2015 10:42 PM
mistermenphis22
Jul 13, 2015 04:43 PM
Kyles24
Jul 12, 2015 09:15 PM
silentz
Jul 9, 2015 08:16 PM
