2000 ex Won't start
Old Jun 20, 2012
Mike1213's Avatar
Mike1213 is an unknown quantity at this point
2000 ex Won't start
Hey guys so I'm having problems with my 2000 ex single overhead cam. The other day I was driving down the freeway and it started jerking really bad and then completely died. Luckily I had triple A and they towed it home. It cranks but won't fire. I checked the fuel pump it humms a little and I attached a hose where the fuel filter would go and got a ton of gas so that works. I installed a new fuel filter. Still no fire. So I pulled the spark plugs set them all on the exhaust shield and cranked it and they all have spark. So I have spark and fuel. Is there a censor or something that may have gone out? It just cranks and cranks but won't fire.
Thanks for any help.
Mike
Old Aug 23, 2012
mariodg98's Avatar
mariodg98 is an unknown quantity at this point
Re: 2000 ex Won't start
Exact same thing happen to me, shuttered on highway, then died. Plenty of fuel, spark, new dist cap, rotor, good ignitor, still can't get it running, timing belt was less the 2 months old and still attached ok. Not sure what to do next, been parked for a couple of weeks. Thinking about checking timing marks, looks like a big job though. U have any luck?
Old Aug 24, 2012
marek91's Avatar
marek91 is an unknown quantity at this point
cam sensor behind the dizzy? are you throwing any CEL's ?
Old Aug 24, 2012
mariodg98's Avatar
Well I did connect and odbc reader, got no codes, but did get input from cam sensor when it was turning over, bar graph went up and down.etc, not sure if there is more then one, if within range. After it died it ran for about a second, never ran again.
Old Aug 25, 2012
mariodg98's Avatar
Update
Well I decided to try a "new" coil pack from eBay for 14 bucks, I had spark, and same resistance as the autozone ones, but did notice Raimbo heat mark on plastic so decided to give it a try, and to my surprise after a lot of turning the car turned on. I immediately got a p0335 light, I drove it a while, and reset, hasn't come up yet, car still hesitation when I stomp it but seems to get better, starts quicker and quicker, no stalls from a stop light. Still sputter when I stomp though, I a guessing maybe the cheap coil I bought? Looking for an oem.
What_It_Do
May 10, 2015 05:31 PM
usajags84
May 10, 2015 08:11 AM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
black2k1vtec
Dec 6, 2001 09:49 PM
