Will coasting in Neutral improve mpg? Will that have an affect on the trany?
Old Feb 15, 2011
mike98's Avatar
mike98 is an unknown quantity at this point
I was wondering this because i have an auto and whenever I'm coasting the transmission is still engaged so the engine is reving 1500's.
But when i switch it to neutral RPM drop to 600, therefore it will use less fuel. Plus in neutral i can coast for a longer distance.
The only concern i have is that this will weaken my transmission.
Old Feb 16, 2011
Xx7thGenxX's Avatar
02 Civic, Coupe
Xx7thGenxX is an unknown quantity at this point
Re: Will coasting in Neutral improve mpg? Will that have an affect on the trany?
i dont no what it will do to your tranny, i have a manual transmission and when i aproach hills (downhill) i always put it in neutral, it does improve mpg so it would be the same for yours, im not so sure about an automatic tranny going in and out of neutral though...
Old Feb 16, 2011
MelJ's Avatar
Trance Addict
Actually, you're better off coasting in gear. I can't remember the stuff off the top of my head, but it takes more gas to keep the car running in neutral.
Old Feb 16, 2011
Newfiedan's Avatar
Newfiedan is a jewel in the roughNewfiedan is a jewel in the roughNewfiedan is a jewel in the rough
Mike your reasoning is flawed and will cause premature break wear on the car. The tps position is at 0 when you release the gas pedal rpms are not a good means of judging gas usage when coming to a stop, if the tps is at 0 then the car puts in no more gas than when its idling, the rpms raise is just the cars trans downshifting to assist in stopping, its not using more gas to do that. 16 years of working on cars and learning the ins and outs of how they work has taught me that.
Old Feb 16, 2011
Fuel injection, that is. When coasting it will not be injecting more fuel, rather less.
Old Feb 16, 2011
mike98's Avatar
Alright guys, thanks for clearing that out for me.
I used to do it but always had a bad feeling about it lol.
Old Feb 16, 2011
more fuel used in neutral than in drive, and its always a bad idea to force the trans into gear (or neutral) while the car is moving.
danace99
Oct 17, 2015 02:51 PM
BBrosario
Sep 17, 2015 07:51 PM
Donahue
Sep 9, 2015 05:55 PM
Bricoleur
Sep 9, 2015 12:30 PM
