d16y7 problems.
Old Oct 11, 2010
sRGB's Avatar
sRGB is an unknown quantity at this point
d16y7 problems.
first off, I'm a complete noob, and just got my car 2 months ago. However I'd like to learn how to fix my car independently, Id appreciate the help anyone can give me, and please don't tell me to take it to a mechanic because I'm inexperienced (we all have to start somewhere).
Okay so I know this d16y7 has common issues with the idle erratically going up and down. Recently my idle has been fluctuating and I didn't think much of it, so I kept driving it, but as of yesterday, the engine check light (Malfunction indicator light) popped up. Can someone help me out here?
I know it is the IACV, and I know where it is. Can someone tell me how to take it out? Is it as simple as removing the 4 bolts on the throttle body, then removing the 4 bolts on the IACV, then cleaning it with brake cleaner? I want to take it out, but I'm afraid that If I take it out, I might not know how to put it back together. for example, is there a certain amount of torque that needs to be applied when assembling, or is it just tighten until you cant anymore.
Another thing I read was that it may be the o2 sensor, Ill try fix the IACV problem first, and if that doesnt fix it. Where is the sensor, and what can I do to fix it?
The next problem is also common (from what I have read) there a little bit of oil leaking from the distributor, and it is drippy down. anyone know how to remedy this problem?
Old Oct 11, 2010
Ggsbassist's Avatar
Ggsbassist is an unknown quantity at this point
Re: d16y7 problems.
Check the code then search what that code is for. You'll have a way better idea of where to start and won't have to spend time fixing something that isn't broken.
Old Oct 12, 2010
sRGB's Avatar
Re: d16y7 problems.
how do I check the code?
*edit:
Nvm, got the code. 14 aka IACV.
I guess I'll be cleaning that, if it doesnt work, I'll probably replace it.
Old Oct 13, 2010
Re: d16y7 problems.
Get a Haynes repair manual in any auto store in case you don't have one - will not have everything, but will help you on the easiest ones and you can have it next to you during the work.
brash99
Sep 29, 2015 08:42 AM
Bruce2
Sep 27, 2015 08:45 PM
Styven Szastur
Sep 23, 2015 05:26 PM
Bruce2
Sep 21, 2015 08:01 PM
MamaBear2015
Sep 15, 2015 09:35 PM
