map sensor
Old Nov 12, 2008
goob408's Avatar
goob408 is an unknown quantity at this point
map sensor
how do i test the map sensor
Old Nov 12, 2008
TRIZ's Avatar
Re: map sensor
I dont think you need to test it- if it goes bad your ECU will throw a code. To check if a code is thrown, plug in a odb2 scanner to the odb2 port under the right side of the steering wheel.
Old Nov 12, 2008
goob408's Avatar
Re: map sensor
i have a good ecu i put aother ecu and the same thing happen
BootyDo
Jun 21, 2016 03:45 PM
jzhartman
22
Jul 23, 2015 10:42 PM
mistermenphis22
Jul 13, 2015 04:43 PM
aultman1990
Jul 9, 2015 08:27 PM
CivicsClass101
Jul 9, 2015 11:14 AM
