D17a1 engine swap
Old Oct 22, 2018
Cessna99's Avatar
Cessna99 is an unknown quantity at this point
D17a1 engine swap
Hi new to the forum. In 2 weeks I'm going to be swapping my engine in my 2004 civic dx. I bought a 2005 d17a1 engine complete with wiring harness so it should be plug and play. Just want to make sure because I'm doing the swap 500 miles from home where my car broke down and don't want to run into anything major. Is their any thing I should watch out for while swapping the auto tranny.
Old Oct 22, 2018
BrotatoChip's Avatar
Super Moderator
Re: D17a1 engine swap
I would suggest getting rid of the engine harness from the replacement and using the stock one from your car. Do both engines have EGR?
Old Oct 22, 2018
Cessna99's Avatar
And how do i tell?
Old Oct 22, 2018
Cessna99's Avatar
So the new engine doesnt have egr but the old one does. Is this hard to deal with
Old Oct 23, 2018
Super Moderator
If the original engine does not have EGR but the new one does you will need to swap the coolant passage/EGR manifold along with a new intake manifold gasket. This also means you will need to use the original engine harness and not the one from the new engine. Other than that I believe this will be a direct swap.
Old Oct 23, 2018
Cessna99's Avatar
The old engine has egr but the new one doesn't.
Old Oct 23, 2018
Colin42's Avatar
make the new engine look like the old one, use the old harness
Old Oct 23, 2018
Super Moderator
It doesn't appear I can read very well. Just reverse what I previously said. It really is as easy as making the new look like the old as Colin states.
Old Oct 26, 2018
Cessna99's Avatar
And is it true the engine from an se is different and can I tell what model of car this came out.
Old Oct 27, 2018
Colin42's Avatar
The only difference is EGR and/or VTEC, there should be a vin plate on the engine somewhere, if you can decode that you'll know what kind of car it came out of
Cessna99
Dec 27, 2018 12:55 PM
krs
Oct 21, 2013 10:04 AM
hawkeye81
May 4, 2013 03:25 PM
affixrider
Mar 11, 2008 11:57 PM
