Motor swap
Old Feb 15, 2018
Carlos24's Avatar
Carlos24 is an unknown quantity at this point
Motor swap
Was up fellas . I swap my D17a2 with a d17a everything is working good now after a few minor issues. But now when I hit 4000 rpms car boggs like it's red lining . I swap the VTEC solenoid thinking it was that but it still does it . Some say it can be the ECU. Any help will be appreciated. Thanks
Old Feb 15, 2018
Re: Motor swap
go to a car part store and have them read the codes
Old Feb 24, 2018
Carlos24's Avatar
Re: Motor swap
Hey fellas sorry it took so long but here are the codes I got p1259 p1298 p0600 p1457 . Any help would be appreciated. Thanks
Old Feb 24, 2018
Re: Motor swap
P1259 is causing the low rev limit. Fix the VTEC problem.
Does your valve have the pressure switch on it? Does it work? Does the wiring do what it needs to?
Did someone get the vtec solenoid wire mixed up with the oil pressure sender wire on the back of the engine?
Old Feb 25, 2018
Re: Motor swap
and the VTEC is activated by engine oil pressure - if low, it will trigger the code
Dretoven
Feb 9, 2018 01:58 PM
quietriot732
Jul 20, 2014 09:51 PM
95turbocivic
Jul 24, 2011 05:08 AM
spoonEM
Jan 30, 2008 03:44 PM
DC
Sep 16, 2002 05:25 PM
