2002 Honda Civic EX
Old Feb 26, 2018
Willie1003's Avatar
Willie1003 is an unknown quantity at this point
2002 Honda Civic EX
Hello I just bought a 2002 Honda Civic and want to start modifying it. I'm not sure where to start tho. Any suggestions or ideas?
Old Feb 26, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
Re: 2002 Honda Civic EX
suggest you thoroughly evaluate what you're starting with, and decide what your end goal is. here is a post from a close friend that has run a successful hot rod shop since the 70's and still designs and manufactures parts for a variety of cars. please read and consider it.
I thought that this may be somewhat helpful to members?
While I hold for almost 30 years a current ASE Mater Technician L1,L2, certification and California Emission License. I also keep myself well updated on the lasted technology more specifically in the PERFORMANCE parts industry. I never the less at times own a vehicle which does not really fit my normal consideration for what I would deem to be a worth while investment in upgrading to performance levels. However I have thus far enjoyed my M3 and will tinker around with projects for fun sake. Since I am still some what a new here on this forum and many are still getting to know me a few members reading many of my responses have been now pm'ing for advise as they seem to feel that at times the threads are confusing to them for answers and oftentimes result in a feeling of unresolve for choosing some part upgrades. So this thread may help with the first foundation that everyone either experienced or new to Performance upgrades should think about and consider a basic plan of action for upgrading engine Performance parts.
Parts upgrades THINK
Always do a thorough check and evaluate the condition of your car prior to any modification. It might be common sense but unfortunately it is not always the case when adding new upgrades to your car.
This means if you do not know the mechanical condition or current state of engine operation don’t assume anything. Check everything. All too often lately many have been doing performance upgrades only to have issues and assume that it is the new parts installed.
ANY engine upgrade that will improve the level of performance like horse power or torque will also exponentially increase an already existing engine problem.
This means that not only have you created bigger problems but you have made it much more difficult to trace the original source of the problem.
Consider everything needed for any upgrade and also how one upgrade will effect all the other parts already on your car before you install them. Check carefully every new part by fully examining them prior to the installation. And don’t cut corners to make things easier for the install.
There are more than enough qualified people i.e. Vendors, Shops, ECU tuners, manufactures etc. around willing to help you in the decisions of upgrades and to suggest additional parts that might be needed or servicing with your new upgraded parts BEFORE you install them.
Careful consideration and planning of your upgrades can save you disappointment and most of all money.
Because many cars are over 5 or more years old and some approaching more then 80k+ miles it is VERY important to take the time and do a simple compression test of your engine before ANY new engine modification are installed.
There are too many problems that are not indicated before new performance engine parts are installed. Installing them without a simple compression test will make it extremely difficult to track down problems after there install.
All shops doing installs of performance engine parts should make this part of the installation process of new engine performance parts. It takes less then 30 minutes with experienced technicians and anyone can do it to their own car in about an hour.
Recently several problems have been brought to my attention for resolution about new performance parts installed by both shops and garage DIYer's via PM's.
After spending some time to help with these issues and parts being suspect the results were, the prior (pre existing)operating condition of the car less than even factory specification,none related parts broken,dirty, damaged. Improper installation or installation procedures damaging new parts. The short block or lower engine worn out indicated by a subsequent compression and leak down evaluation after new performance parts installed. These are just a few which could have saved the owner a lot of time and money had one basic pre compression test performed.
One other thing...DONT get discourage by some members saying that you will never feel or get only but a very small result of some upgrades you do. Remember that very small thing that adds even a small about will eventually add up to something worth while.
i know that probably reads like he's a know-it-all but he truly is a smart old fart i look up to. i myself neglected a simple compression test before sticking a supercharger on my beater. the first time i exceeded 4krpm, the dipstick popped out from blowby and the oil spray on the header made a spectacular smoke show behind me. my accomplishment turned into embarrassment and a really hard to fix and completely untuneable problem.
what condition is the car in now? what type of car do you want to end up with? (: i suggest if you don't know, buy a few import magazines and see what you do and what you do not like. while you read them you can get your car into the best possible version of it's stock running form first. by the time it's at 100%, you'll likely have some idea what you want to improve on. not a mechanic, and new here, so just my 2¢
Old Feb 26, 2018
Willie1003's Avatar
The car is in perfect condition. Only 60k miles and the only thing that was wrong with it was the lower control arms which I just got fixed.
Old Feb 26, 2018
Slumpertcivic's Avatar
General holy grail is to turbo it..
FENG
Nov 23, 2003 05:06 PM
SMBFC
Oct 19, 2003 10:39 PM
krayziebonet4l
Nov 12, 2002 02:44 PM
Outkast27
17
May 20, 2002 03:19 PM
