Driver door lock problem
Old Aug 6, 2013
jturner's Avatar
jturner is an unknown quantity at this point
Hey everyone,
My problem is that my key will go into the slot but will not turn at all, I did buy it preowned so maybe a previous driver replaced the lock but I do not think so. Also, the power door lock switch and keyless entry will not do anything to the driver's side door, but will work for the passenger door. I've been having to manually lock the door and then go through the passenger side to unlock it. I've pulled off the door panel and cannot see if anything is wrong, although I am nowhere near being a mechanic. The power lock switch on the driver's side door does work, but will only lock/unlock the passenger's side door, so there is power to that switch. Any ideas on what to look for or what part might need to be replaced? Is this a common problem with this generation of Civic?
Old Aug 19, 2013
armydave's Avatar
armydave is an unknown quantity at this point
Re: Driver door lock problem
I just bought a 2003 Civic LX and am having the same exact problem. I am guessing that the actuator is going bad. They can be found pretty cheap on ebay. I have been on here as well researching it for a couple days now and can't really find much. I am also looking to find out if my car came with keyless entry already installed and the dealer just lost the fobs.
Old Aug 20, 2013
Poopies's Avatar
Super Moderator
Originally Posted by jturner
Hey everyone,
My problem is that my key will go into the slot but will not turn at all, I did buy it preowned so maybe a previous driver replaced the lock but I do not think so. Also, the power door lock switch and keyless entry will not do anything to the driver's side door, but will work for the passenger door. I've been having to manually lock the door and then go through the passenger side to unlock it. I've pulled off the door panel and cannot see if anything is wrong, although I am nowhere near being a mechanic. The power lock switch on the driver's side door does work, but will only lock/unlock the passenger's side door, so there is power to that switch. Any ideas on what to look for or what part might need to be replaced??
I have a similar problem with my driver side electronic door lock but the key DOES work. It's most likely an actuator problem. jturner, it sounds like your cylinder is busted. Here's an '03 LX part list and diagram: http://estore.honda.com/honda/parts/...b=B++5310&dl=#
armydave, your car is one year too old for that. Doesn't sound like a tough mod though: https://www.civicforums.com/forums/1...ss-remote.html
Old Aug 20, 2013
CraigW's Avatar
Standard keyless on LX trim is 04+
Nalmonte
Exterior
Jan 24, 2020 04:55 PM
MamaBear2015
May 18, 2015 07:37 PM
maaronia
May 14, 2015 10:46 PM
MamaBear2015
May 3, 2015 02:17 PM
darwin-t
Apr 18, 2015 09:29 PM
