best suspension setup??
Old Nov 7, 2011
canadiankid's Avatar
canadiankid is an unknown quantity at this point
in the spring i want to lower my 01 civic sedan (preferably on full adjustable coil overs) from my little understanding of suspension set ups i will need the full coil overs and since i want to go at least 2inches lower i will need a camber kit.
i would also like to stiffen up the suspension, what is the best bang for my buck i can get in the way of sway bars and/or rear lower tie bars, i have heard that on our 7th gens you can't install both, is this true?
any suggestions on set ups would be great!!
thanks,
Jay
Old Nov 8, 2011
Re: best suspension setup??
Check the stickies at the top of the suspension forum
https://www.civicforums.com/forums/4...on-performance
as far as suggestions go.. I'm personally a fan of tein suspensions, and they apparently re-vamped the BASIC coilover, and made the street basis.. I don't quite know the differences off hand, but you can search for it a bit. In fact, here's a link from thmotorsports.com: http://thmotorsports.com/tein/tein_d...s/g-64305.aspx
that's where I heard about the new coilovers. Those are adjustable height but not dampering.
As far as "bang for buck" upgrades, you can't go wrong with an RSX 19mm rear sway bar. Since you have an lx (which, don't come with a stock rear sway bar, if my memory serves me correctly), you're gonna have to install endlink mounts. I'm not too sure about the ins and outs of adding a sway bar on an LX, but I'm sure you can find it easily or someone will chime in.
Also, the neuspeed front upper strut bar is one of the best out there. I heard they discontinued them, but it still shows up on their website.
Old Nov 8, 2011
tie bars will stiffen chassis, not suspension, so low priority there.
coilovers will stiffen the suspension by spring rates and higher damping.
don't get front sway, stock is good enough already. rear sway is what a FWD needs.
Old Nov 9, 2011
lowlife9's Avatar
ahhhhhh Progress technology coil overs and ''cough'' Progress technology rear sway bar that comes with a tie bar and Progress technology sway bar adaper kit.
http://www.corsportusa.com/store/cat...roducts_id=481
http://www.corsportusa.com/store/cat...roducts_id=324
http://www.progressauto.com/products.../productID/477
Old Nov 10, 2011
sl33pyriceboi's Avatar
^for our civics, progress coilovers is FAR FAR behind KW, tein (flex or ss), even koni/GC
if u want the "best suspension setup" go with the KW...but ur gonna be spending 2k on it.
if u are not doing autoX, then it is almost (subjective) a waste of $$$$ unless u have too much disposable income.
Old Nov 10, 2011
lowlife9's Avatar
far far behind tien my *** what you think just because tien is damper adjustable its a better overall product. and far far behind koni/GC i don't think you know what your on about.
Old Nov 15, 2011
Balzdpr's Avatar
A scene before your eyes
Balzdpr is on a distinguished road
Hey, I gotts a foot. You wanna shoot me in it too.
Tedverseti
Apr 23, 2020 01:45 PM
Tedverseti
Sep 29, 2015 05:41 PM
czarlun
Sep 14, 2015 08:16 PM
