Oil Breather
Old Nov 5, 2011
hondafixit's Avatar
hondafixit is an unknown quantity at this point
Oil Breather
Honda civic 1.7 CDTI - had problems with EGR valve twice in a year with excessive carbon build up.
Is there an oil breather on the block ?? Filter ?? Location
Any advice please
Old Nov 5, 2011
lazlong's Avatar
Re: Oil Breather
You're a little unclear? There's no breather. There is an oil filter but, if you haven't changed the oil and filter in a year that's probably your problem. Oil and filter should be changed regularly. Do a top-end cleaner (like sea-foam) and change your oil and filter.
A rich fuel/air mixture (running rich) can cause excessive carbon build-up. A bad internal part (piston ring, valve guide, etc) can also cause it.
Old Nov 5, 2011
Re: Oil Breather
possibly clogged pcv valve. its metal so you can take it off and spray with carb cleaner
Old Nov 9, 2011
fordsmith's Avatar
fordsmith is an unknown quantity at this point
Re: Oil Breather
I think the oil is the most important part in the engine to run engine smoothly . For that you have to change the oil within 7-8 months in the regular basis. And also the oil filter. So that the oil can run in the engine better. You should simultaneously check and reinstall the oil.
Old Nov 9, 2011
lowlife9's Avatar
Re: Oil Breather
definitely take off and clean the PCV valve or maybe a crack in the hose running to it. the system runs off the vacuum created buy the air intake putting on a breather won't help much.
Old Dec 30, 2011
hondafixit's Avatar
Re: Oil Breather
this egr valve is playing up again so will need to check the pcv valve.
where is it ??? a diagram be handy unless its easy to find lol
Old Dec 30, 2011
SpdySylvrEX's Avatar
SpdySylvrEX will become famous soon enough
Re: Oil Breather
It's on the back of your block. Lay under the car, with front of the car above your stomach, head under your IM, look up. There should be a hose going to the back of your block. Heres a pic...
Old Dec 30, 2011
hondafixit's Avatar
Re: Oil Breather
Originally Posted by SpdySylvrEX
Attachment 82292
thanks will have a look tomorrow - hopefully wont be raining
emich
Dec 11, 2015 12:20 PM
SidCivic
17
Aug 23, 2015 03:14 AM
CdnRD
Aug 21, 2015 11:42 PM
fafa1234
Aug 8, 2015 06:42 PM
fecrni
Aug 8, 2015 06:15 PM
