Passenger window goes up but not down
Old Jan 3, 2011
stevelaw18's Avatar
stevelaw18 is an unknown quantity at this point
Question Passenger window goes up but not down
I have a 2-door 2004 civic.
The driver side window switch can raise and lower both the driver side window, and the passenger side window. No problem here.
The passenger side window cannot lower the window, but it can raise it if its been lowered from the driver's side.
I tested the passenger side switch, and all the states appear correct, so this is not the issue. I checked the fuses, and they are fine as well.
To me it seems like the child safety switch is not releasing somehow, or shorted...something like that. I've tried pressing and releasing the child safety button a bunch of times, but no luck.
I'm sure I probably just have to replace the window master switch.
Anyone ever have this issue? Any ideas what the issue could be, or how I can troubleshoot this?
Thanks
Old Jan 3, 2011
Re: Passenger window goes up but not down
sounds like passenger switch to me. if the driver master switch works, there is no reason to replace it. and if the child lock thing was on, none of the buttons would work.
Old Jan 3, 2011
DarkSouljur's Avatar
DarkSouljur has a spectacular aura aboutDarkSouljur has a spectacular aura about
I'm having the exact same problem with the back passenger side window on my 4 door 2002 civic :/
Old Jan 3, 2011
stevelaw18's Avatar
So if the child lock is on, then the passenger cannot even raise the window if it's already down? I wasn't sure.
I was assuming that since the Window Master Switch contains the circuit board that also appears to control the child safety button, that this must have gotten screwed up somehow.
I tested all the pins on the passenger switch and all appeared ok. Now you have me second guessing myself. I will try to test them again.
Old Jan 3, 2011
CraigW's Avatar
The safety switch will inhibit both driver and passenger switches from moving the window up or down. Only the drivers window works when safety switch on.
I would try measuring voltage to the motor.
wingsfan19
Oct 1, 2015 03:45 AM
Sep 27, 2015 11:33 AM
Dave Brabant
Sep 9, 2015 08:11 PM
Wiggles
Sep 8, 2015 05:05 PM
rainman15
Sep 6, 2015 11:10 AM
