Problem with my em2!...
Old Sep 3, 2009
em2_jdmboy's Avatar
em2_jdmboy is an unknown quantity at this point
i recently got a 2004 em2 ex... with my first tank of gas i did 370 miles and with my last 2 tanks ive done bearly 300... also the gas niddle goes down then up as im driving and when i turn on the car again it goes down... does anyone w\know what can be wrong?... :confused::confused::confused:
Old Sep 3, 2009
hypnotic20's Avatar
hypnotic20 is an unknown quantity at this point
Re: Problem with my em2!...
First off the needle guage is horribly inaccurate. When I drive slow it's telling me that my car is seemingly making gas, but we all know thats wrong unless that's honda's trade secret...
Anywho that portion is normal. With the change from 370 to 300 could be a lot of things, like do you weigh more? Is there more items in the trunk? If you have aftermarket parts, do they weigh more than the stock parts?
Also how is your driving? Do you rev it up and day dreaming that you're in a supercar? Or do you sit back and realize its an economy car and keep the RPMs low?
So many factors... not to mention a dirty car creates strong drag that does lower your MPG.
Quick recap on what can decrease MPG:
- AC is on
- Aftermarket parts IE(strut bars, subwoofers, exhaust systems, bigger wheels, etc)
- Dirty car
- You put on a body kit that is not aerodynamically better for the car, and may weigh more too.
- You are using a stronger alternator to power subs
- You are using more energy by having more electrical components that require a lot of energy (subs, amps, neon lights)
Last but not least, your ECU reset but you didn't let it relearn how to consume the gas. This was probably done when you disconnected the battery. So what do you think it is?
Old Sep 3, 2009
em2_jdmboy's Avatar
its completly stock... no extra items are in the trunk or more weighted added to the car... i wash the car once a week... i dont rev it past 2500... i used cruise control alot too...i know its not for speed so i dont try and dream about something thats not going to happen... -__-... so idk what it can be... gas isnt keep i cant keep driving like this...
Old Sep 3, 2009
ADMCivic's Avatar
ADMCivic is an unknown quantity at this point
One of the biggest factor really is what roads you are driving on. The tank where you did 370 miles, was that mostly highway and the 300 miles tank were they city? I average over 400km a tank with mix driving ive gone below that with pure city and ive pushed 600km on pure highway.
Old Sep 3, 2009
hypnotic20's Avatar
ADM brings up a good point too, the highway. Are you always in stop and go traffic, or a constant smooth speed?
Old Sep 3, 2009
em2_jdmboy's Avatar
well I only drive like mas 10 miles a day... i dont go pas 45... idk... my cousin said i should take it to honda and put the computer on it to see if somethings wrong?... what do you think?...
Old Sep 3, 2009
GreenMachineDX's Avatar
GreenMachineDX is an unknown quantity at this point
Check Your Spark Plugs, Air Filter, Tire Pressure - There is a information on the tire just look for the (PSI). I think its like 35 or somethiing..
If every thing that i just said its fine, Then Check Your gas filter.. Also wut kind of octane u fill it up with?
Old Sep 3, 2009
Awjvail's Avatar
Awjvail is an unknown quantity at this point
Daaaammmmn. 400km city? 600km highway?
I get 600km per tank easily on nearly pure city driving A tank of gas lasts me 2 weeks!
Different driving styles I guess.
Old Sep 3, 2009
ADMCivic's Avatar
Ive read that the 01s get a little worse mileage, i dont know why. I dont rev the car hard too, i always shift at the recommended shift points.
Another point too is how far you drive, your mpg wont be as efficient for the first few miles since your cat and engine has not reached its optimal temperature.
That could be why my mileage in the city sucks, i only work 8km from home from one job and 1.5km from my other.
Old Sep 4, 2009
ADMCivic's Avatar
Just thinking it over and looking at my records I rarely put in more than 35L so if I did go a full 50L i could do easy over 600km on city driving
Old Sep 4, 2009
hypnotic20's Avatar
problem solved!
Old Sep 4, 2009
What you mean problem solved?
Thats Not the same guy who posted this thread...
Old Sep 4, 2009
wallydude03's Avatar
wallydude03 will become famous soon enough
Originally Posted by hypnotic20
problem solved!
huh?
Old Sep 5, 2009
em2_jdmboy's Avatar
i change my spark plugs like 2 weeks ago... the tires i check them everytime i put gas and i put 89 oct of gas... ive only done 150 miles on half a tank... =( ...
Old Sep 5, 2009
em2_jdmboy's Avatar
how do i check my gas filter?...i read it was inside the gas tank?... sorry im new to the honda world...
Old Sep 5, 2009
hypnotic20's Avatar
The fuel filter is actually on the outside of the tank I believe. Somebody correct me if I'm wrong, it should be on the passenger side of the car, near the back tire.
Old Sep 6, 2009
lowlife9's Avatar
i believe thats the evap filter your talking about the fuel filter is in the gas tank.
Old Sep 6, 2009
cloud2987's Avatar
cloud2987 is an unknown quantity at this point
hmm i think the the fuel pump is in the tank and the filter is outside the tank..
Old Sep 6, 2009
fuel filter is inside the tank actually, as part of the fuel pump. its a 4hr+ job to replace it. i had the same problem as the OP did, and turns out alot of these cars have a faulty fuel sending unit. i had times where the needle would read empty but i still had over 5 gallons in there. it would never be accurate until they changed the sensor. now its much better. also the road will mess up the gauge reading. if youre on flat ground, it will be very accurate, but on hilly ground where the car is not flat, the fuel reading will change.
Old Sep 6, 2009
batman900's Avatar
batman900 will become famous soon enough
Same, my fuel light will come on and it only takes 8 gallons to get it to full soooo I had like another 5 still sitting in there. .....
edit: is there a diy for this or is it pretty hard and should be left to a dealership? also will it just start happening again after replacement?
Old Sep 6, 2009
i had the dealer do mine, it involves taking out the fuel pump from the back seat (tell them to be careful and not spill gas all over like they did with mine). i would say its harder than the average diy job. i had mine fixed in 2003? i think and never had a problem since then. my car is a 2002.
Old Sep 7, 2009
em2_jdmboy's Avatar
okkk..thanks guys for all the help... i'll see what honda tells me...
Old Sep 7, 2009
Hmm Fuel Filter In The Tank?? Never saw that....
Old Sep 7, 2009
well youre welcome to search under the hood, but you wont find any fuel filter lol
Old Sep 7, 2009
Old Sep 8, 2009
I know its not under the hood or anywhere close to the motor... Fuel filters are usually under the car by the fuel tank... But in the tank... Never heard of it.. Learn something new everyday...
FurBall
Jun 10, 2015 03:13 PM
DouglasTheGreat
May 27, 2015 11:23 PM
elitezdc5
May 26, 2015 05:46 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
Ronin
Nov 17, 2001 09:46 PM
