No pressure to clutch pedal
Old Jun 15, 2013
jsubskustomz's Avatar
jsubskustomz is an unknown quantity at this point
I started off having to manually pick up my pedal with my foot and they pedal would work fine. Changed the master and slave cylinder, bled everything and now no pressure to pedal at all. Paid a mechanic to fix it, he was confused and had no clue and still took my money. Please help
Old Jun 15, 2013
GolNat's Avatar
Prelude Owner
Re: No pressure to clutch pedal
Did you bleed it completely? My slave failed on me and it took a lot of pumping after it was replaced to get it to build pressure again.
Did you check for a leak in one of the lines?
Old Jun 15, 2013
I replaced the clutch hose, the line from the hose to the slave also. And I have bled it completely to my knowledge. How long did it take to do yours?
Old Jun 15, 2013
GolNat's Avatar
Prelude Owner
I dont remember exactly but I remember thinking that something else was wrong because it was taking so long. It eventually started to get hard and finally held pressure. If you didn't bench bleed the master it will take longer when you do it in the car.
Old Jun 15, 2013
What is the best way to bleed it?
Old Jun 15, 2013
GolNat's Avatar
Prelude Owner
Fill up master cylinder all the way up with fluid. Also fill a bottle (soda bottle) with brake fluid (about an inch). Open the bleeder valve on the slave. Put a piece of hose on the end (fuel line works). Place the other end of the hose in the soda bottle. Make sure the end of the hose is completely submerged in the fluid you don't want any air to get in. Then have someone start pumping the clutch. As the fluid goes away in the master fill it back up with new brake fluid. It should eventually get hard if you don't get any air in and there are no leaks.
Make sure the hose stays submerged in the fluid the whole time!
Old Jun 16, 2013
about how long did it take? 30 min? a couple hours?
Old Jun 16, 2013
GolNat's Avatar
Prelude Owner
I remember it being under 30 minutes but my wife things it was longer. She was the one pumping the clutch. I had to fill the master bottle twice I think.
Old Jun 16, 2013
well we worked at it for about an hour, filled the bottle about 10 times and still nothing
Old Jun 16, 2013
GolNat's Avatar
Prelude Owner
Only other thing I can think of is if you got a bad part.
Did you get an OEM slave and master?
Old Jun 16, 2013
beck arnley slave and i have put 3 different master cylinders from my work (O'Reillys) on it
Old Jun 17, 2013
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
Two things come to mind. First, is the slave cylinder mounted correctly? I'm not sure on the Civic but on other cars I have seen where it is possible to rotate the slave cylinder 180 degrees and mount it with the hose at the top and the bleeder at the bottom. The bleeder valve has to be at the highest point to get the air out or you will have a pocket of air.
When you bleed brakes or a clutch you need to open the bleeder valve as someone is pushing down on the pedal and close it before they hit the bottom. The valve is left closed while they let the pedal back up forcing it to draw fluid from the master. If you leave the bleeder open and push the pedal up and down you may end up with a bubble that does not get forced out.
Old May 27, 2014
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
I replaced my clutch slave cylinder and had a lot of difficulty bleeding afterward. I bought this: http://www.harborfreight.com/brake-f...der-92924.html pneumatic brake bleeder for $28.
Followed instructions and bled all the air, clutch pedal pressure returned and it feels great!
Old May 27, 2014
kinakoes2's Avatar
*watches temp gauge like a hawkboss* :D
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
Fill res.
Pump pedal a few times.
Hold down and have helper crack open bleed screw.
Repeat until no air comes out.
If you have a bit more money, get a pneumo bleeder like a MityVac. The reason you use them is just to pull the fluid into the system. Then once you can get pedal pressure, THEN bleeding can happen. The filling part can take a long time with just the pedal method, where it can be done in 10 mins with the MV.
Old May 27, 2014
bsmiley's Avatar
I've seen a lot of posts about dead clutch pedals after slave cylinder repairs. The line from the master to the slave is long and has lots of curves. If you have a good compressor, the pneumatic bleeder is the way to go. Took about 30 seconds of bleeding to get the bubbles out and pressure back. I had pumped the clutch pedal with a line and jar for about an hour yesterday and the pedal was just starting to get a little pressure.
If you don't have a compressor that can handle 90-120 psi, go for the manual pump. But for certain, the clutch can be a pain to bleed...
Old May 27, 2014
bsmiley's Avatar
[QUOTE=kinakoes2;4664776]Fill res.
-Yes, did that for an hour. Spent $28 on a pneumatic vacuum bleed kit and did it by myself in 60 seconds. I hope to help others so they don't fart around for an hour with a helper when they can do it by themselves with the right tool.
Old Sep 26, 2019
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
I have similar issues with my 02 civic..i just replaced the clutch and reinstall everything in the reverse order and when i got done my clutch pedal doesn't have any pressure to it..i took the tranny off again to make sure everything was ok but still nothing. I bled the line using half a bottle of brake fluid and still nothing changes..i dont have any leaks from my master cylinder or slave cylinder. You have any idea what could causing this?
Old Sep 27, 2019
BrotatoChip's Avatar
Super Moderator
Sounds like air in the clutch line. Did you have someone help when bleeding? Should be bled similar to brake lines, one person pushing the clutch while another is opening/closing the bleed valve.
When I bled mine the other person had to pull the clutch back up a few times before enough air was bled out of the line.
Old Sep 27, 2019
No, it was only me doing it.i got a bottle with about 2 inches of brake fluid in it with a tube insert all the way to the bottom and the other end on the bleed valve and open the valve and keep pumping the pedal and adding fluid so it don not run dry. I bled it for about 25 minutes until i can see no air in the line. Its the same way i did my brakes.
Old Aug 29, 2021
Ninjaturkey's Avatar
Ninjaturkey is a jewel in the roughNinjaturkey is a jewel in the roughNinjaturkey is a jewel in the rough
I tried hand pumping and another person pumping the pedal without success. I wound up using a Power Bleeder with the euro attachment. One person held it on to the reservoir to keep the pressure even, the other pumped it to 12 psi and opened the bleeder.
​​​​​​​Since I use old threads regularly to figure out how to fix things, hopefully this thread necro is forgivable and useful.
bryan1995
Jun 28, 2016 06:38 AM
KLD2177
Sep 2, 2014 06:17 PM
01 civic LX
May 28, 2014 11:10 PM
civicsrcool
May 6, 2009 06:37 PM
civic01vtec
Jun 12, 2007 09:32 PM
