HELP ME PLEASE!!! alarms
Old May 19, 2003
italginny's Avatar
italginny is an unknown quantity at this point
Angry HELP ME PLEASE!!! alarms
HELP ME PLEASE
i tried to replace my alarm horn with a air horn but it did not work. so i then tried to put it back i only touched 2 wires the power and the ground. but now the alarm is steadily going off and its low you have to b close to it to hear it. i can disarm the alarm it self and start the car but the horn doesnt shut up.
please help me fast.
Old May 19, 2003
skipbarber's Avatar
what kind of alarm?
Old May 19, 2003
cambo's Avatar
I wish I was asian
want horn to shut up? take horn out. horn no make noise no more.
Old May 19, 2003
skipbarber's Avatar
that works too
Old May 19, 2003
italginny's Avatar
its a honda factory installed alarm.
Old May 20, 2003
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
Wow ?!?
The horn is not loud, but does not shut up???
Everything works ok, except the horn ??
Check all the fuses, though it's doesn't sound like a fuse problem
Sounds like a wiring problem,
Horn is getting steady low current,
instead of strong sudden current, when used
I DUNNO ..
Best of luck though !
Old May 20, 2003
italginny's Avatar
one fuse was blown so i replaced it but still the same. is there anyway of reseting the alarm box. its an automate.
Old May 20, 2003
OMega's Avatar
OMega is an unknown quantity at this point
Sounds like the air horn drew to much current. I think you fried the horn part of the circuit. Put it back as best you can and take to the dealer and tell them it just started acting funny. More then likely to hole system going to start flaking. Next time use a relay.
Old May 20, 2003
italginny's Avatar
hey thanks i was just check to see if the air horn worked so i left the air horn out.
what a mistake, ouch
i brought it to a friends shop and he told me i fried the brain. so he put a new brain. now it works better then when honda put it in. he told me that the brain was already messed from before.
Old May 20, 2003
italginny's Avatar
mistake correction
hey thanks i was just checking to see if the air horn worked so i left the relay out.
frank_kleng
Sep 29, 2015 10:55 PM
MamaBear2015
Sep 24, 2015 11:34 AM
meicalnissyen
Sep 22, 2015 06:20 PM
Dsmak
Sep 10, 2015 08:30 PM
First Car
Sep 8, 2015 08:54 PM
