DIY VTEC Light (with Pics)
Old May 16, 2003
  #151
Boilermaker1's Avatar
Jap-Euro Fusion
I don't really understand what it is your asking... you want to know how to wire an LED? The long lead is positive, the short lead is negative, hook it up to power and make sure you use a resistor large enough to reduce the voltage to a level the LED can take.
Old May 17, 2003
  #152
Xplocv2k1's Avatar
myspace.com/misterwarren =]
Xplocv2k1 is an unknown quantity at this point
whats a good resistor size?
Old May 17, 2003
  #153
Jap-Euro Fusion
Totally depends on what the source is putting out....
Voltage = Current* Resistance
Get a multi-meter... measure the voltage and current being put out by the source.... then read the LED package to find out what the maximum Voltage and current the LED can handle.... Solve the V=IR equation twice, once for LED max V = Source current* R, and Source voltage= MAX LED Current *R... solve for R... select the higher number of the 2... that is the minimum you can use. anything with more impedance than that is ok.
Old May 19, 2003
  #154
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
Thanks Boilermaker1, this DIY was really helpful and easy. It was even easier for me since I bought an led that already came with the resistor and led housing installed (this complete led kit is real nice since the housing is flat and not round like led snap-in housings), so all I had to do was tap pos. and ground neg. (so simple). Like everyone else, I am very surprised how early VTEC kicks in about 2500-2700 and I'm not even pressing on the gas real hard (only halfway down to 2/3's tops).
Old Jul 22, 2003
  #155
perry's Avatar
perry is an unknown quantity at this point
**** this is a long thread... ya know what, i always thought that my vtec engaged around 4000... thats weird. are you guys sure it doesnt have variable levels of engagement, like the celicas... once slightly, then once again greater?
Old Jul 22, 2003
  #156
NorrinRadd's Avatar
Probably, after driving with the VTEC light now for sometime it sometimes engages early sometimes later. It has a lot to do with how much gas you give it, the more then the earlier it engages (2500-2700), and less would be around 3-4k.
Old Jul 22, 2003
  #157
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
yes, the 680 ohm resistor works the best...
you notice that it stays on after 63mph?
Old Jul 23, 2003
  #158
NorrinRadd's Avatar
Yup, and no matter how much I ease the gas... it always stays on after 70-72mph.
Old Jul 31, 2003
  #159
Vtec02Hon's Avatar
Vtec02Hon is an unknown quantity at this point
Boilermaker1,
I have a question. I see you have a Oil Pressure Gauge. If I may what wire did you hook the sender wire up to? There are three on the back Positive, Negative and Sender ( I think ). I don't know where it could possibly be or where to hook it up. I went to the DIY portion and under electrical it shows four connectors that plug to the ECU. One of the wires is labeled as VTEC oil pressure switch. Would this be the wire, but it is labeled Switch? Thank you very much. Derek
Old Aug 10, 2003
  #160
Player1's Avatar
Player1 is an unknown quantity at this point
New suggestion for this DIY. For those of you that have indiglo emblems, wire it up to the light. Personally, not something I'd do myself tho.
Old Aug 11, 2003
  #161
2k3HonCivicEX's Avatar
2k3HonCivicEX is an unknown quantity at this point
Originally posted by FlyRiceRacer02
haha........here is what it should look like
the resistor goes on the side with the vtec wire, the long lead of the led. the resistro wont do anything for the grounding point.... n00b, haha im just playin, im retarded god ill stop typing now
Old Aug 16, 2003
  #162
JLODVO's Avatar
JLODVO is an unknown quantity at this point
hello but we have 2 vtec ryt? can we wire 1 lead for the first vtec and another 1 for the 2nd vtec?
Old Aug 16, 2003
  #163
civicvtec1ps's Avatar
Search and Learn
Old Aug 16, 2003
  #164
VTECTypeR's Avatar
Old Aug 16, 2003
  #165
WannaBFast's Avatar
Prowlin' with a Purpose
well.. its not htat simple... its 2 stage vtec... but it seems like its just like it gets more juice than simply have a second wire...
Old Oct 15, 2003
  #166
pon's Avatar
pon
pon is an unknown quantity at this point
Boilermaker1 you said to hook the resistor to the ground lead did you mean the positive lead
Old Oct 15, 2003
  #167
Jap-Euro Fusion
No I didn't. Current runs from negative to positive... so it passes the resistor first.
Old Oct 27, 2003
  #168
chesireCAT's Avatar
chesireCAT is an unknown quantity at this point
Alright, I did this and I put the light on my gauge pod on my A pillar looks very sweet right next to my A/F guage.....but damn if that light doesn't come on all the damn time....when does vtec kick in for us? Is the yellow/green wire the wrong wire? It almost acts like a map sensor wire or something....cruising on the highway at 80+ and it's always on....
Brandon
Old Oct 27, 2003
  #169
ben_spawn's Avatar
ben_spawn is an unknown quantity at this point
ok here's the deal. i've recently re-visited this post again. im doing circuit engineering now in school. i'm guessing that when vtec kicks in, a current of certain amps would flow. since we're wire-tapping in this case, that would cause the current to split right? hence the vtec current that flows would be lesser than the original (the original being without the wire splice). anyone have any idea on how would that affect the circuit?
Old Oct 27, 2003
  #170
Elite's Avatar
Elite is an unknown quantity at this point
Brandon
yes its called stage 2 vtec kinda like intellegent timing unlike older models they always kicked in at around 4500 rpms
Old Oct 27, 2003
  #171
Jap-Euro Fusion
Considering an LED takes current on the order of mA, I highly doubt there is any effect. All that signal is doing is piggybacking anyways... its wired in parallel, and VTEC is looking for a voltage signal ... Parallel voltages are the same, therefore the LED does nothing to effect the engagement.
Old Oct 27, 2003
  #172
ben_spawn's Avatar
ohh cool. so vtec kicks in when there's a difference in voltage across two points in the circuit.
one more note, as far as i've known, LED are current suckers...they love currents. so they'll suck up alot of current. have you heard about this tho? I'm just trying to verify this.
hmmm oh yeah boilermaker, i think it shouldn't matter where you wire your resistor because wiring it before the LED or after the LED, shouldn't make any difference. i don't think it would though because the current that enters the LED has to be same current that leaves the LED. the thing with LED's is that it allows current to flow in only one direction (anode to cathode--following convention).
Old Feb 7, 2004
  #173
rowdy847's Avatar
rowdy847 is an unknown quantity at this point
everyone should check this place. beats radio shack any day in the led department.
http://superbrightleds.com/
Old Mar 3, 2004
  #174
draganjr's Avatar
draganjr is an unknown quantity at this point
what gauge is the vtec wire from the ecu? 18?
and with Voltage does the LED have to be?
thank you
Old Jul 9, 2004
  #175
Bullet's Avatar
Bullet is an unknown quantity at this point
Talking
Just did it and it works pretty good. For a tempary place to put the led just get a small gromet and put it on the led, place it right between in the crack between the center concial and the vertical concial. It will not go further than an inch or so but pretty good fit. Low and still visable. It was pretty easy to do but just make sure you don't keep the positive and negative wires togeather. Heat shrink will work if you dont have soder and heat shrink. I used soder to connect the wires, put heat shrink over both sides and 3M tape to hold both togeather. You can check the L.E.D. with a 9 voilt. Resister works and you can try it with it on and with out it. Oh make sure you connect it to the lower white connecter. Green line with yellow stripe. Thanks for the info!
Old Jul 10, 2004
  #176
wez20011's Avatar
wez20011 is an unknown quantity at this point
Vtec 3 stage? Philippines
we are told that we have a 3 stage Vtec engine here. (D16W8) that's our engine model here installed to a 7th gen civic. was wondering will the same wire be used? or totally diffrent? since I hear my engine change sound at 3000rpm maybe we have same ECU? but with and additional solenoid for the 3rd stage? or is it all bull? man I'm totally confused here... is there really a 3 stage Vtec 1.6 engine manufactured by honda?
Old Jul 10, 2004
  #177
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
LED's use a dropping resistor to LIMIT the current to a few mA, which is safe for the LED. Take out the resistor and "POP". That's why you need a resistor of a given value for a given voltage.
Old May 5, 2005
  #178
01civi's Avatar
01civi is an unknown quantity at this point
I too now have mine installed but also bought the infrared emitter instead at least I had some LEDs lying around
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Wild Cranker
427
Jan 28, 2016 06:49 PM
stryder12
Jun 30, 2015 08:33 PM
MiniMi
May 27, 2015 01:57 PM
ImmortalEX
Nov 8, 2001 09:52 PM
