DIY VTEC Light (with Pics)
Old Apr 21, 2003
  #61
R3DL1N3's Avatar
AHHH!!
ok, tap splic: on
now how do i go about connecting the end of the wire running from the splice to the long LED pole, and how do i connect the resistor to the short pole
Old Apr 21, 2003
  #62
CarbonFly's Avatar
Heat shrink tubing
Old Apr 21, 2003
  #63
R3DL1N3's Avatar
would that not be too big? what about if i just wrapped them together with electrical tape
Old Apr 21, 2003
  #64
CarbonFly's Avatar
do you even know what heat shrink tubing is? It comes in all sorts of sizes. You can get it at radio shack in an assortment pack. Slide it on. Heat it up with a lighter and bam your wires are covered securly instead of using electrical tape which could come off or have other stuff go wrong.
Old Apr 21, 2003
  #65
R3DL1N3's Avatar
ahh got ya
Old Apr 21, 2003
  #66
R3DL1N3's Avatar
i hate my life...
ok, did the tap splic thing and made the new wire to the LED, used electrical tape and taped those together. then i got a resistor and taped one end to the small pole on the LED and the other end to pretty much everywhere else inside the cig compartment place. still no LED lighting up...someone shoot me
Old Apr 21, 2003
  #67
CarbonFly's Avatar
Are you actually moving in the car when you are testing it? You can't just sit there and rev it. You have to at least be rolling.
Old Apr 21, 2003
  #68
HondaLuver's Avatar
Its a celebration bitches!
my V-AFC tells me when my vtec is on...
Old Apr 22, 2003
  #69
Connie's Avatar
In between classes today I ran to radio shack and spent less than $14 (including 55 ft. of wire) and installed the whole shabang, I wanna go try it out now.....can't wait. I really suck with cars and I did it, the hardest part was drilling because I didn't want to take the peice out of my car to drill it, It already has wires running into it, Will get pictures later in my profile.
Old Apr 22, 2003
  #70
Connie's Avatar
There is a metal bar behind the cig lighter when you pull the panel out. There is only one screw with a small black wire running under it. Put it under that screw, that is what I did, I have to sit through this class before testing to see if it works.....Oh the Pain!
It DIDN'T WORK!!!! Damnit! Now I have to trace back and find my problem, I have bigger gauge wire (not single) and I twisted the wire to the resistor then shrinked it.....umm.....does it matter which end of the resistor is which direction, otherwise I have no idea.....
Old Apr 22, 2003
  #71
Boilermaker1's Avatar
Jap-Euro Fusion
The direction of the resistor doesn't matter, the direction of the LED does. Make sure that's right. Also double check that your connections are actually touching. It's also possible that during the twisting that you tore the lead out of the resistor body.
Old Apr 22, 2003
  #72
ben_spawn's Avatar
ben_spawn is an unknown quantity at this point
does it matter if u connect the resistor to either of the legs of the LED?
Old Apr 22, 2003
  #73
CarbonFly's Avatar
The resistor needs to be connected to the short led end.
Old Apr 22, 2003
  #74
Jap-Euro Fusion
Dammit Fly.. you beat me to it... PW
Old Apr 22, 2003
  #75
ben_spawn's Avatar
yeah i read that, but dont the current run from the wire tap into the LED and then grounded? shouldn't you reduce the current before it enters the LED?
On that note too, if I were to add a toggle switch to enable/disable the light. Where should be the best place to insert it?
Old Apr 22, 2003
  #76
CarbonFly's Avatar
Fine, don't listen to us. Don't pay attention to the 2 guys who have successfully completed this project. How would we know? We only did this perfectly!
He|| I even did it on another 7thgen yesterday 2!!! so taht is 2 cars under my car for this project.!!!
Old Apr 22, 2003
  #77
ben_spawn's Avatar
bah u dint have to flare up yo. all u have to said was u dont know. i'm just trying to figure out how it works so i could work on other electronic parts without having to bug the forum ppl all the time.
my bad!
Old Apr 22, 2003
  #78
Jap-Euro Fusion
Why the resistor is in series with the ground is a bit of a mystery to me too... because I too was thinking like you. However I could not make it work.
The for the toggle, you can put it anywhere... all you have to do is break the circuit. I'd put it between the VTEC wire and the LED because it would be easiest.
Old Apr 22, 2003
  #79
ben_spawn's Avatar
i'm afraid if i tap into the wire at that section, current might be too much at the point perhaps burn up the switch? if that's possible. i'm seriously not sure. so that's why im figuring out on which points has the safest amount of current to tap in a switch. plus on page 4, i have this idea of a 2 LED light, i'm not sure if the idea of the setup would work. if i know how the current runs then prolly i could work on it. thanx for the reply btw.
Old Apr 22, 2003
  #80
R3DL1N3's Avatar
ive dont just about everything possible besides soldering the **** together. can you solder the tapped wire to the long end of the LED?
Old Apr 22, 2003
  #81
MangoEX's Avatar
Just Be
MangoEX should not be trusted
One more thing... Fly where did you get access to the VTEC wire? from the ECU or under the hood, its a blue wire right? (not green as pictured in your diagram)
Old Apr 22, 2003
  #82
Samari's Avatar
I dont know about the 2 led thing the guy came up with. Come on, really is it necessary. When the LED is lit up that means the VTEC is engaged. When the LED is not on, neither is vtec. WOW! I give him credit for the idea though.
Old Apr 22, 2003
  #83
ben_spawn's Avatar
lol sorry im a freak with jetplanes =) i just love switches and lights in my car =) gotta admit that =)
Old Apr 22, 2003
  #84
Jap-Euro Fusion
The VTEC wire is the Green/yellow stripe wire in the middle plug of the ECU. It's the one with the arrow on it in the pic on the first page.
Old Apr 22, 2003
  #85
hankscorpio's Avatar
hankscorpio is an unknown quantity at this point
You can put the resistor anywhere in that circuit and it will work fine. I too thought it should go on the positive side of the LED and so i wired it that way and it works fine. Then i thought i'll try it the way they said and see if he made a mistake or what, and that way works fine too. You learn that **** in physics I. The resistor will effect the entire circuit it is in, so you can put it in either place.
As for the idea of the switch, that too can go on the positive or ground end of the LED. IMO i would put it on the positive end.
Old Apr 22, 2003
  #86
KD5FTN's Avatar
KD5FTN is an unknown quantity at this point
I'm thinking about installing a small dimmer. FYI, it's basically a variable resistor, so I can change brightness and turn it off.
I wonder if I'll be able to find a potentiometer (dimmer switch) and led in one.. that would be nifty
Old Apr 22, 2003
  #87
Connie's Avatar
I checked over my stuff and my dumb *** bought an infared LED and thats why I wasn't seeing anything. I see it perfectly now but it turns on whenever I accelerate, even at 2,400RPM I used the 470 OHM resistor......any sugestions on what it might be?
Old Apr 22, 2003
  #88
R3DL1N3's Avatar
uhh, ok when you guys are talking about grounding the wire on the thing behind the cigarett lighter are u talking about that copper holder with the black wire, or actually ON the cig lighter?
Old Apr 22, 2003
  #89
Jap-Euro Fusion
Sounds like it's working properly.
The black wire that goes to the Cig lighter harness is grounded.
Old Apr 22, 2003
  #90
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
well mine works but i am sure it will be removed soon maybe due to the annoyance factor.
Injen
