MISSING LINK VALVE Q
Old Jan 30, 2003
drag's Avatar
drag is an unknown quantity at this point
ok first of all what is a missing link valve and wat does it do.secondly i think ACE646 made one at home so can some one tell me how to make one and where exactly to put it.by the way where does it go anyway.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 30, 2003
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
I belive they are only for turbo set ups. So unless you have a turbo, you have no need what so ever.
Old Jan 30, 2003
Grey's Avatar
DIY King
There's this thing called a MAP sensor. Manifold Absolute Pressure It's a pressure sensor that is in the intake tract that helps the ECU determine how much fuel to add. Since there's less air in the mountains than there is at sea level the ECU will add less fuel to have the optimum air/fuel ratio. That's why people complain that their car is really slow in the mountains. Anyway, with a turbo setup the MAP sensor would be buggin' out since it would read pressures way above atmospheric. The check engine light will go on and the ECU might actually put the car in limp mode. A mode that reduces the rpm's and increases the fuel to protect the engine from failure. Anyway, the Missing Link Valve fixes this.
Ahem: DIY D17 Turbo - Now Accepting Donations
Civic15
18
Sep 19, 2017 07:48 PM
fordover
Jul 11, 2015 09:10 PM
General 7th Gen
Jul 9, 2015 10:17 PM
trellex
Electrical
Jul 9, 2015 12:01 PM
CivicsClass101
Jul 9, 2015 11:14 AM
