TRANNY SWAP.....questions on the ECM wire harness
Old Oct 4, 2002
ilv4nos's Avatar
ilv4nos is an unknown quantity at this point
TANNY SWAP.....questions on the ECM wire harness
hello, hope you guys can answer this for me i am a beginner as far as tranny's are concerned, anyway i found a 5 speed for my civic complete with clutch and ecm i am assuming these items are the only thing i have to swap out of my car ...do i have to swap the ecu out and also is the harness to the ecm interchangable....i am sure these are easily swapable i just need some more direction here, me and friend are making the swap, he recently swapped his auto in his mustang for a cobra r manual.....all flames requested...this is my way of research on this very site...to learn more about my car, so tell me if i need anything else...the pedals are obvious...thx for all info...also i plan to make a diy on this...
My Civic
Old Oct 4, 2002
taz757's Avatar
Well, along with the ECU and stuff, my guess is that you're going to need a new gauge cluster too. Plus, you're probably going to need a new trim ring and stuff for the center console. On top of that, there's nothing else that I can really think of that you'll need.
Old Oct 4, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
Console and cables? and the shifter assembly? All the hydraulics for the clutch? Reservoir, slave cylinder etc....
I don't see why you need a new cluster [IMG]i/expressions/face-icon-small-confused.gif[/IMG] as long as it's not a DX, there's a tach... that's all you need. To run cruise control, I don't know... I'm not sure how its set up on both models. Using a Manual ECM may let you keep the cruise, but I'm not sure what sensors are involved. The clutch will shut off the cruise, but I don't know if there is a sensor somewhere, or if it is a mechanical switch.
Old Oct 4, 2002
RedDragon333's Avatar
good luck looks like your started out on a good note...good thing your DIY otherwise you might as well bend over and get ready...[IMG]i/expressions/moon.gif[/IMG]
Old Oct 4, 2002
01civ01's Avatar
01civ01 is an unknown quantity at this point
you'r gonna need axles from a manual trans, ecu and harness from trans, your gonna have to replace your auto flexplate with a manual flywheel, slave cyl. hydralic plumbing, pedal assembly, shift linkage, shifter, clutch cable and brakets, and a reverse light switch if it didn't come with the new trans.
BootyDo
Jun 21, 2016 03:45 PM
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
jzhartman
Jul 9, 2015 04:56 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
