2 Throttle Cables
Old Jun 16, 2002
ZRPM's Avatar
ZRPM is an unknown quantity at this point
2 Throttle Cables
I want to follow the DYI and adjust my throttle cable, but I have two. On is for the cruise control I think. Anyone know which one to adjust? Should I do both? I'm thinking I may go to the dealer and say throttle response is sluggish and get them to do it [IMG]i/expressions/face-icon-small-wink.gif[/IMG] I only have 130 KM on the car so far.....
Old Jun 16, 2002
Macko's Avatar
Macko is an unknown quantity at this point
adjust the one that dosen't look like it runs to the cruise control drive motor (a box) it's most likely the one towards the firewall and down
Old Jun 16, 2002
speedracersong's Avatar
i dont recommend in tightening the throttle cable because its a waste.
ur going to be reving the car in neutral before u dump the clutch in a manual or brake torquing it if u have an auto. so the tightening the throttle cable really has no use.
Old Jun 16, 2002
Captain's Avatar
Captain is an unknown quantity at this point
Yeah, I wouldnt waste the time. Its barely noticable.
Old Jun 16, 2002
Decamo's Avatar
Decamo has a little shameless behaviour in the past
I did it to take up the slack and have better throttle response. The way its set stock is annoying, when your on the freeway and you want to accelerate there is a pause b4 the throttle responds. Taking up the slack reduces this pause.
Just don't go overboard like some ppl where they've run into problems with higher idle speeds. Easy to put back though if this happens. Just mark the wire with a marker b4 you start.
Old Jun 16, 2002
Dustman380's Avatar
Dustman380 is an unknown quantity at this point
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] 188242_2_full.jpg (37 Kb)
Old Jun 17, 2002
tummyboy's Avatar
tummyboy is an unknown quantity at this point
I tightened mine i like the response differenance but you do rev neutral like "speedracersong" said but thats only till you get used to the response. if you have an auto I dont know what it will do but engin braking would make sense but when accelerating you would kick down faster so thats a plus
Old Jun 17, 2002
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
Quote
[hr]Originally posted by: Decamo
Just don't go overboard like some ppl where they've run into problems with higher idle speeds. Easy to put back though if this happens. Just mark the wire with a marker b4 you start.[hr]
its a honda, not a f1.....
Old Jun 17, 2002
DannyK35's Avatar
I'm bigger than you.
DannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to allDannyK35 is a name known to all
Don't waste your time w/tightening the throttle cable, you'll either waste your time and get a placebo effect, thinking it made a difference but it really hasn't, or you'll just screw up your idle.
Not worth it IMHO, and should be taken off the DIY page
Tyler93
Mar 20, 2016 09:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
Bruce2
Sep 27, 2015 08:45 PM
Matt T
Idle Issues
Sep 24, 2015 04:53 AM
Bricoleur
Sep 9, 2015 12:30 PM
