Returnless system...........
Old Jun 14, 2002
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
I know youīre all gonna flame me but ive searched and couldnīd find an anwser.... what the f#ck does a Returnless Fuel System do??? Why is the so much trouble with them??? Why canīt you add a turbo???
Old Jun 14, 2002
PerfectD3's Avatar
PerfectD3 is an unknown quantity at this point
do a better search
Old Jun 14, 2002
VNlilMAN's Avatar
The Standard One
not 100% sure but from my understanding, you could let the fuel flow at a high rate that is needed with a turbo. when the turbo doesn't kick in and doesn't require more fuel, the fuel return will return the unused fuel back in the fuel tank...
since we have a returnless system, we could probably tune our cars for turbo but when it doesn't kick in we are left with all that fuel that has no where to go since we dont have a fuel return.
i dont know jack about turbos or any engine mod tho so dont quote me on this, still have alot of learning to do myself.
Old Jun 14, 2002
But what is a returnless fuel system.......
Old Jun 15, 2002
Silver2k1Dood's Avatar
Silver2k1Dood is an unknown quantity at this point
Alright guy...just think about it: On a regular fuel injection system, there are 2 fuel lines; one going to the fuel rail/pressure regulator to supply fuel to the injectors and another one to scavenge leftover fuel from the fuel rail and return it to the tank.
On our cars, there is more precise metering and atomization of the fuel so as to promote better burn efficiency and eliminate leftover fuel, hence the return line is not needed.
This is what is meant by a "returnless fuel system". Hope this is clear now.
Old Jun 15, 2002
thanks..... i never got on awser on that question before.............................
Old Jun 15, 2002
LeroyBrown's Avatar
LeroyBrown is an unknown quantity at this point
props 2k1 dood, you are a good guy to have around..
Old Jun 15, 2002
PerfectD3's Avatar
Quote
[hr]Originally posted by: Silver2k1Dood
This is what is meant by a "returnless fuel system". Hope this is clear now.[hr]
Ummm, actually, the returnless system does not optimize fuel etc. It is only there for emissions purposes. Fuel that is brought to the engine bay is heated up, then when that leftover fuel is returned to the fuel tank, it heats up the rest of the gas and causes vapor. Vapor through the engine causes hydrocarbons, the source of a stinking tailpipe (high emissions). The returnless fuel system is not more precise when it comes to fueling, it is more of a crude system, but it is cheaper to build, has lower emissions, and is easier to service on (ie. diagnose a problem and fix).
Old Jun 15, 2002
Quote
[hr]Originally posted by: PerfectD3
Quote
Ummm, actually, the returnless system does not optimize fuel etc. It is only there for emissions purposes. Fuel that is brought to the engine bay is heated up, then when that leftover fuel is returned to the fuel tank, it heats up the rest of the gas and causes vapor. Vapor through the engine causes hydrocarbons, the source of a stinking tailpipe (high emissions). The returnless fuel system is not more precise when it comes to fueling, it is more of a crude system, but it is cheaper to build, has lower emissions, and is easier to service on (ie. diagnose a problem and fix).[hr]
WTF are u talking about? I never said the lack of a return fuel line optimized the fuel system...at least KNOW what you are talking about. The ECU in our cars works in conjunction with the VTEC-E system and the redesigned injectors to aid in a more efficient burning of the fuel delivered into the cylinder. If you want to get technical then, yes, the fuel line itself plays a role, as the in-tank fuel pump's output is regulated and varied according to the engine's needs...this is why there is no return fuel line and why it's called a returnless fuel system. Again, this single fuel line system is made possible by better injector nozzles, ECU fuel maps, and VTEC-E actuation of the intake valves and the resulting optimized fuel supply and usage.
Old Jun 15, 2002
1slo2k1civic's Avatar
1slo2k1civic is an unknown quantity at this point
Old Jun 15, 2002
[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Jun 15, 2002
PerfectD3's Avatar
Good lord, get all hyped up. My mistake man, just misread your post. LOL, calm down. BTW nice pic
EDIT: WTF. Know what the hell I am talking about. Dear god, thats why I mostly just float on this site. Your not going to turn into another PinkyToe incident now are you? Don't worry about replying with some hyped up attitude, Ill just continue to float because its not worth it to argue. If you truly know about cars, then props to ya, seriously, but if your another one of these dumbarses that just read over stuff on the net and then think you know it all, blow me.
Old Jun 16, 2002
Fa5ter's Avatar
Fa5ter is an unknown quantity at this point
Dude, our returnless fuel systems still provides more than enough fuel and pressure to accomodate a turbo or nitrous. If you are interested in having it done for you, www.openloopmotorsports.com
It'll run you about 4k installed.
- Fa5ter
sitinduk
Jan 2, 2006 10:19 PM
Boosted2k2
Engine Swaps
16
Aug 11, 2003 04:47 PM
SODJAZERO
Engine Swaps
Apr 8, 2003 08:16 AM
cdmx
Mar 11, 2003 08:58 PM
FiresVTEC
Feb 6, 2002 07:58 PM
