Hey a newbie here...
Old Apr 9, 2009
Nav's Avatar
Nav
Nav is an unknown quantity at this point
Hey guys,
I have a Honda Civic not the sporty range but a family range...its a 5 door hatch back MB2 sereis..I have got this problem on my honda's brake which is anoying me for a while now. been to different garages no use, changed the discs and pads and plenty of times still the same problem even new calliper on both sides ...firstly the driver side pads wears of quicker than the passenger side...and secondly, the driver side discs and pads they dont sit properly, i mean the clearence between the pads and disc varies as it rotates. say you take the tyres of and simply rotate the discs with your hand, it rotaotes freely for 3/4 of the way and suddenly it gets tighter, its almost like the disc and the pads are not parallel to each other...any idea....i hope you guys understant what i am saying....
Old Apr 9, 2009
civicplaya's Avatar
civicplaya will become famous soon enoughcivicplaya will become famous soon enough
Re: Hey a newbie here...
When you brake, does your car pull any direction?
If so, it's your rotors.
Old Apr 9, 2009
Nav's Avatar
Nav
nope no pulling...i tired it the other day...30mph and brake no hands on streeing wheel..it slowd down straight line.. u think it has somthing to do with the caliper holders..thas the only thing i havent changed in the brake system...
Old Apr 9, 2009
MestUp6's Avatar
MestUp6 is an unknown quantity at this point
Did U Try Cutting The Rotors Back A Little Bit
You Can Change The Pads All You Want But If U Dont Cut The Rotors
The New Pads Wont Sit Right on Them And They Will Wear Down Faster And
Unevenly And Possibly Make Some Noise
So Look Into That
Old Apr 9, 2009
Nav's Avatar
Nav
i will try that over the week end, as its time to change the pads again...
Old Apr 9, 2009
MestUp6's Avatar
Let Us Know How It Goes
Old Apr 9, 2009
manahoonie's Avatar
did you purchase the car new or used? what year is the car? if you bought it used, it may have had some front end damage, and a part may still be bent.
Old Apr 10, 2009
TRIZ's Avatar
You could always pull the hub from the axle as it might not be sitting inside the bearings correctly... hmm... I dunno, its late. Not worth the trouble. Take it to midas, arent they the brake specialists?
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
cukaracha
Aug 10, 2015 08:01 AM
Farticle69
Aug 6, 2015 08:02 PM
j-chest
Jul 31, 2015 01:18 PM
jzhartman
22
Jul 23, 2015 10:42 PM
