Skunk2 Intake Install Issue
Old Dec 24, 2007
OneCoolDad's Avatar
OneCoolDad is an unknown quantity at this point
I just installed a Skunk2 Intake on my sons 2000 Civic. I can't figure out what is causing the engine to rev. Right now all the hoses have been reconnected and the sensors are re-connected. However, I do not have the air cleaner on. I re-used the original throttle body and it is open to air with no back pressure from the air flow through the filter. Would this cause the engine to rev? Are the sensors backwards, is there no coolant flow yet??? Anyone have any suggestions? THANKS
Old Dec 24, 2007
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
Re: Skunk2 Intake Install Issue
is it revving? or is the idle just higher?
Old Dec 24, 2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
sounds like a vacuum line or IACV.
Old Dec 24, 2007
civic-driver's Avatar
civic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond reputecivic-driver has a reputation beyond repute
i would say hes talking about a higher idle which beadebaserr said is probably cause by a vacumm issue or a dirty sensor. check all the vacuum lines and make sure the sensor is clean and plugged in
carid
Apr 30, 2015 07:00 AM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
ph0ng
52
Mar 4, 2003 09:15 PM
skywalker
Nov 8, 2001 05:04 PM
SneakerPimp
Nov 4, 2001 01:12 PM
