SRS Light Problems
Old Aug 29, 2006
Kung's Avatar
Kung is an unknown quantity at this point
SRS Light Problems
Recently my SRS light came on so I did a search and found something interesting on a thread started in 2005 (so i couldnt reply or directly quote the person who said this)
Animosity says
"Im a mechanic for honda, we get this alot, most of the time a low battery can cause it to come on..."
I remember resetting my SRS light before I got a new battery because it came on (SRS came back on a few days later), but I have yet to try it out after I got a new battery. Just trying to verify/confim if this has happened to anyone.
Anyhow I was just curious, and after reading this I guess I'll try the SRS reset trick again in the morning.
Old Aug 29, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
good question i just bought a SRS reseting peice from HandA store hopefully that works ...hope the batterys fine
Old Aug 29, 2006
Ichiban's Avatar
Ichiban is an unknown quantity at this point
Mine came on after I took out my seat and disconnected the airbag plug. I reconnected it but it's still on.
Old Aug 29, 2006
def01tones's Avatar
You bought a used dog??
def01tones will become famous soon enough
mine has been on for sooooo long, i cant even remember when i noticed it. i disconnected the driver airbag when i replaced my turn signal switch (did it myself before i knew there was a recall), but i think it was even on before that. still pisses me off when i see it but i dont want to take it to honda and get raped to find out why its on.
Old Aug 29, 2006
Kung's Avatar
If you disconnected the plug under your seat then reconnected it with the battery still in, then I can see why your SRS light is on.
There is a DIY on how to reset your SRS light and all you need is a paperclip and probably a friend to look at the dash light so you can concentrate on the paperclip method. It's really quite simple and unless you have a true problem with your SRS system then the light should go out.
I've swaped out my seats with EP3 seats before and had the SRS light come on and all I had to do was the quick SRS RESET DIY. Anyhow, I was just wondering if a low car battery also triggers it (see original post).
Old Aug 29, 2006
skipbarber's Avatar
ive had my battery run down a few times before, and it's never tripped my SRS light.
Old Aug 29, 2006
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
mine comes on once in a while and then it goes off. Im wondering if theres a short in it somewhere. And I have a brand new battery and it comes on at least once a month. Its not on for long but it still comes on. Anybody have a suggestion?
Old Aug 29, 2006
lol go to honda? or buy the part from H&A to reset it the proper way like me beacause its always on for me and my moms a bitch and dosent like it when she sees lights on my cluster other than turn signal s
Old Aug 30, 2006
1sykcivic's Avatar
RHCP0801 is my hero
1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute1sykcivic has a reputation beyond repute
^^ u coulda used a paper clip
Old Aug 30, 2006
paper clip? and should i trust you O_O bad rep! a lor of bad rep !!!
Old Aug 30, 2006
lxcivic2k1's Avatar
Mines been on for a while cause I didn't want to get raped by the dealer either, but I never searched. Maybe I'll see if the DIY helps to get rid of it cause its annoying as ****.
Old Sep 1, 2006
Kung's Avatar
Trust me. I've done the DIY before with the paperclip. If you take a look at the part you got to reset the SRS light you'll notice that it's just a wire that goes into the correct pin holes. This makes it easier for you to connect and disconnect it to the connector on your car.
The plug just completes a circuit with the connector, but you can do the same with a paperclip, piece of metal, piece of wire, etc. People say use a paperclip because it's metal and you can easily shape it into a "U" shape so you can hit the pins on the connector coming from you car. It's just a little more tedious to use a paperclip, but whatever saves me a buck or two these days is worth it (gas is crazy expensive even for my little 4 banger).
Old Sep 1, 2006
Michalo187's Avatar
Abortion Survivor
mine has been on forever....it doesn't matter but i heard if you put something heavy on your seat and don't buckle the seatbelt it comes on....also if yo d/c your seat and leave it d/c.
Old Sep 1, 2006
jameStype's Avatar
jameStype is an unknown quantity at this point
i took mine in under warranty the other week for free. it was a seat belt buckle sensor that was causing it. they ordered a new buckle and the install is going to happen tomorrow at no charge to me.
Old Sep 2, 2006
doctor's Avatar
Type-Race
doctor will become famous soon enoughdoctor will become famous soon enough
I took out my rsx seats the a month ago and when I put them back, that damn srs light wont go away. Ive done the paper clip trick before, but this time it dosent seem to work. I follow the DIY. but the blinking (signifying the erasing of the srs) happens like on the second try and then the light stays on after the blinking. Any help?
jimmyfloyd
May 20, 2015 07:06 PM
Ma213802
May 18, 2015 07:01 AM
cukaracha
May 16, 2015 02:11 PM
bo_red
Transmission
May 3, 2015 09:14 PM
SimDogg
Nov 27, 2001 04:20 PM
