pleeease help help help.!!
Old Aug 6, 2006
minorc's Avatar
minorc will become famous soon enough
I'm clearing out my headlights, took the clear cover off the headlight but the screws on the inside aren't Phillips head screws. i Mean they look like them but there is a metal thing inside it, It would look like an octogony type of screw with a metal tip inside it so i can't get at it with my phillips screwdriver., pleaaaase help anyone. Anytype of screwdriver gonna remove this thing?
Old Aug 6, 2006
you must have a coupe. sedan is just a philips. i think you need some alen wrenches?
Old Aug 6, 2006
bp_22ca's Avatar
bp_22ca is an unknown quantity at this point
I have a sedan and have never had my headlights apart... but sounds like you either need an allen key or a torx wrench with the center drilled out.
Old Aug 6, 2006
minorc's Avatar
like very small allen keys"? yes i have an 03 coupe, plz msg back if you know anything im desperate and don't want to break it
Old Aug 6, 2006
JB Dizzle's Avatar
JB Dizzle has a little shameless behaviour in the past
i think i know what you're talking about... there's like an octagonal shape thing instead of a cross in the screw... i had the same problem... but what i did was just use a small head phillips and started twisting it... and walla!... i unscrewed it... i'm guessing you have an 03? try using a smaller head phillips to unscrew it
Old Aug 6, 2006
minorc's Avatar
no dice, not even close, the smallest phillips that i got is too big, my old man says it could be a screw the dealer put in there so you couldn't tinker with it. any ideas? anyone else done this to a coupe?
Old Aug 6, 2006
bp_22ca's Avatar
are the sides flat or kinda rounded? If they are flat then you need a hex/allen key. If they are kinda rounded in then you need a torx key. If there is a pin sticking up in the center you need to drill out the center of whatever size it is.
Being automotive I'm gonna guess it's a torx head, I've used a 2mm (.080") drill bit to drill out the centre of a T20 torx head for something else before.
Old Aug 6, 2006
BlackKnight008's Avatar
420 Member
BlackKnight008 has a spectacular aura aboutBlackKnight008 has a spectacular aura aboutBlackKnight008 has a spectacular aura about
yea its problay an allen key and the dealer cant put anything on there that you wouldnt be able to take off without the right tools
Old Aug 6, 2006
04hemiboy's Avatar
04hemiboy is just really nice04hemiboy is just really nice04hemiboy is just really nice04hemiboy is just really nice
Black one allen key. Silver is torx. I suck at teh picture takin.lol There is also a torx that you can get that has a hole in the center of it.
Old Aug 6, 2006
CraigW's Avatar
Security Torx maybe ??
Old Aug 6, 2006
04hemiboy's Avatar
That's what I think too.
Old Aug 6, 2006
minorc's Avatar
Well i re-sealed er all up and didn't get to finish it, but on the bright side i do have a new signature.
Old Aug 7, 2006
04hemiboy's Avatar
So what type of screw was it?
ken4444
Sep 30, 2015 07:37 PM
juicetayne
Sep 30, 2015 11:02 AM
frank_kleng
Sep 29, 2015 10:55 PM
Islesfan
Sep 29, 2015 03:42 AM
C-Hamm
Sep 28, 2015 10:31 PM
