Help for wiring a Switch
Old Apr 7, 2006
mikemal's Avatar
mikemal is an unknown quantity at this point
I picked up a couple of these and they have an LED light at the end, made my Ignited. Basically i can assume the wires will be put on in an "in" and "out" fashion at the bottom part but i am curious as to whether the piece on the right should hook up to a power supply or whether this is a ground for the LED, but in that case what would power the LED?
also... i bought 16ga wire to extend this with my engine start button and ignition. i have it figured out how i will be wiring it but will this gauge work?
thanks a lot, i appreciate it.
Old Apr 8, 2006
mikemal's Avatar
some needs to know this.... anyone?
Old Apr 9, 2006
CraigW's Avatar
A guess, Off=voltage supply +12Volt supply, -LED=ground for illumination LED, On=switched +12 volts.
I have some of the wiring info for 01-02 and 03 starting circuit, if you want it PM with E-Mail.
Old Apr 17, 2006
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
Hmmm... My switches normally have 3 prongs on the bottom, but I'd assume that this one would be the same. I'd think the one standing alone on the far right would be a ground, the one under the on position would be your 12v constant, and the remaining would be your line to whatever you are wiring.
Old Apr 18, 2006
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
^ you are correct!
just wired one of these switches myself
Old Apr 18, 2006
R1Style's Avatar
the prong on the right is the Ground.
The two prongs on the bottom are for Power.
Old Apr 18, 2006
diskreet's Avatar
exactly. The LED gets power from the right switch terminal (right on the bottom in that pic) and grouds itself using the side terminal
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
CaptainAmerica
Jan 30, 2002 12:09 PM
Diznavis
Interior
Jan 28, 2002 08:04 PM
LuvMyCivic
Dec 12, 2001 10:02 PM
NukeSilo
Nov 4, 2001 09:37 PM
