Check engine light help
Old 06-02-2005
  #31
2K1Civic17"Gabe's Avatar
Originally Posted by JesterMasque
Did you start the car with the MAF sensor disconnected? Cause if you did then you have to go to AutoZone or Pep Boys and get your codes cleared. If you didn't start it, then I dunno...
our cel goes off automatically. Once the prob is fixed, it will go off. No need to have anybody turn it off. If it stays on, there is a prob. If disconnecting the b attery worked, and it didnt come back on, it should be ok.
and what you should have done instead of driving a few months to let the car learn the new mods. You should unplug the ECU fuse (or disconnect the battery) for about 5 or 10 minutes, and it will reset. Than hook the battery back up and start the car. Let it idle for about 10 minutes. DO NOT step on the gas in this time, no revving. Just let it idle. Than bring it for a little drive, drive however hard you'd like, and it should be good to go. Thats the easiest/quickest way to get the most response from your mods.
Xuhme
21
08-07-2023 03:40 PM
hernandexz
10-28-2021 10:52 PM
jetcare101
05-08-2015 01:33 PM
tylerginevan
04-27-2015 12:29 PM
bahena08
04-11-2015 05:09 PM
Quick Reply: Check engine light help
