headlight plasma questions
Old Oct 25, 2004
msbarrett's Avatar
msbarrett is an unknown quantity at this point
i'm having some problems with my plasma bulbs. i meant to fool around with my casing because i'm looking into clearing my heads, and now my low beams dont work. saying the bulb burnt out would be the easy way to go, however this is the second time since june.
the first time was when i took it into the shop to get my AC motor replaced. i think you have to unplug, or even take it out the casing. it was returned with the low beam not working. i took it back and they said its just burnt out.
well... now i took out the opposite headlight and see how it will all be taken apart. so now the low beam doesnt work on the other side. i was not rough with it when taking it out either.
my question is, is there something going on with the plasmas that i'm not aware of, or am i just unlucky with burnouts?
Old Oct 26, 2004
BassKadett's Avatar
BassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to allBassKadett is a name known to all
There is a recall with the low beams burning out. Take it to Honda and see if your VIN is covered. 100% free. You should have gotten a notice in the mail, unless you recently got your car. They probably won't cover the burnt out bulbs tho.
civic98?
Aug 13, 2015 01:32 AM
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
