Question for cam gear owners
Old Apr 8, 2004
TheCivOwnsYou's Avatar
TheCivOwnsYou is an unknown quantity at this point
I recently installed AEM cam gears in my 2002 ex. Later that day I noticed that the bolts slipped and retarded my timing to the maximum. So i adjusted it back to 1 degree advanced. When I went to start my car it didnt turn over. So now my car doesn't start. I didn't reset the ignition timing... is that why it's not starting now? What else could be wrong?
Old Apr 8, 2004
2k2civic's Avatar
I have a stock cam gear and my car runs fine.
Old Apr 8, 2004
djmota's Avatar
Sounds like the 3 bolts were not tightened properly. check the belt for missing or torn teeth. also check the cam timing. set the engine to tdc with the white mark on the crank pulley lined up Exactly with the pointer on the oil pump. then look at the pully and make sure (at zero degree setting) that the little marks on either side are lined up exactly with the top part of the head on either side. If it is not exact your car will not start or will not idle. but check the belt first it may need to be replaced.
Also a cam gear is a waste unless you have a reground cam or shaved head. I know I own one and gained 2 hp on a dyno by setting it back to zero. you live and learn.
Old Apr 8, 2004
djmota's Avatar
very productive answer
Old Apr 8, 2004
2k2civic's Avatar
The post topic is "question for cam gear owners". I have a cam gear in my car and thought I'd let him know my car runs fine with the stock one.
Old Apr 8, 2004
djmota's Avatar
good point... but you didn't answer the question.
Tedverseti
Apr 23, 2020 01:45 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
159
Jul 5, 2015 09:54 PM
B1zZ
Bolt-on Engine Performance
Jun 2, 2015 11:42 PM
CivicPunker17
Nov 21, 2001 06:14 PM
