help? turn check engine light off
Old Jan 3, 2004
g33s0n6656's Avatar
g33s0n6656 is an unknown quantity at this point
i recintly did the vtec light and wanted a light to come on when my cooling fan goes on so i tapped off the ecu (maybe not the right one?) and the check engine light came on i put wverything back the way it was the vtec light works fine and i just left the cooling fan light disconnected.....does the check engine light go off when the prob goes away or do you have to reset it cause its still there help please????
Old Jan 3, 2004
HondaLuver's Avatar
Its a celebration bitches!
it goes off when the problem is fixed..
Old Jan 3, 2004
g33s0n6656's Avatar
thanks...
i just read another post and they said to disconnect the battery to reset the ecu and that made the light go away and it hasnt come back so i hope that means the prob would be gone cause you would think theoritically the light should come on again if there was indeed a problem but thanks for replying
Old Jan 5, 2004
hornsfaniniraq's Avatar
hornsfaniniraq is an unknown quantity at this point
ive had the same problem when i was messing around under the hood installind an intake. check the manual. it says how to make it go away by doing something like holding the odometer button and turning the key and holding it or something. that should clear it up.....
Old Jan 5, 2004
g33s0n6656's Avatar
thanks
Old Feb 26, 2004
g33s0n6656's Avatar
turn off light?
if its the maintenance light yes you can hold that button when you start the car for like 20 sec
but if its the check engine light just remove the negative lead from the battery for bout five min same thing happend to me when i mess with the ecu
Old Feb 27, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
Re: turn off light?
You don't have to go through the trouble of disconnecting the negative lead. Just go into the fuse box in the engine compartment and remove the FI fuse for like 5-10 minutes. It cuts the power to the ECU.
Old Feb 27, 2004
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
RESET INFO HERE
scroll down the page to find how to reset the maint. light.
-Locked-
Injen
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
Jay28TU
Nov 11, 2001 07:08 PM
