Please help 1997 civic ex fuel pump wont prime or engage
Old Apr 24, 2015
Jonnie.'s Avatar
Jonnie. is an unknown quantity at this point
So my 97' civic ex wont start up. I have changed the main relay, the fuel pump, and the Distributo, checked fuses, and checked the ground to the fuel pump ive by passed the kill switch. Ive gone as far as buying a meter and checking the power going to the fuel pump power is running to the connector but the pump will not kick on at all. Please help im at my wits end....
Old Apr 24, 2015
Stock 99's Avatar
Re: Please help 1997 civic ex fuel pump wont prime or engage
If you have power and ground going to the fuel pump but no fuel pump then you need to check your connections are good and clean (not corroded). If so then pull it and test the pump itself.
Old Jan 13, 2019
dulceenvy's Avatar
dulceenvy is an unknown quantity at this point
Sounds like it needs reprogramming.... how did you bypass kill switch? did you ever get it fixed if so fill me in please my 04 civic acts as if its stolen the green key light flashes on dash and wont start the radio had been replaced and the spark plugs. I bought a used stirring coloum with key since i was changing it myself instead of buying just immobilizer but it wouldnt work im not sure what to do PLEASE HELP any advice?
Old Jan 13, 2019
Colin42's Avatar
'97s don't have an immobilizer, yours does, you need to get the ecu programmed to the ignition
crazyone64
General
Apr 16, 2019 12:52 PM
Redhead818
Engine start problems
Jul 1, 2018 04:15 PM
thefinder808
16
Jun 17, 2013 10:05 PM
lionel_lampkin
Oct 22, 2012 02:53 PM
tdbaker156
Oct 31, 2011 09:59 AM
