Fuel Fliter...
Fuel Fliter...
hey how do you get to our's and is hard to change out.
thanks.
Matt C.
o yeah how often should it be replaced
thanks.
Matt C.
according to the dealer and a ex honda tech who was my teacher, they are lifetime filters. they only need replacing when fuel system pressure drops below the rated PSI, or possibly when changing the fuel pump. other then that, you dont need to change it. I changed mine because I thought otherwise and after the install, the fuel pump failed. dont know why, but the filter is a about $60 from the dealer and its located in the fuel tank. its attached to the fuel pump assembly. autozone has one for like $25, but it may be wrong. the filter isnt a small filter, it looks like a can with arms.
Originally Posted by shroomster
it's not MEANT to be ......
kinda like your car's pistons. they are not a serviceable part, because there is no interval at which you're supposed to change them out.
Crayons taste like purple...
not serviceable means it has no maintenance schedule, or is not a scheduled maintenance part.
Touge
Sep 1, 2015 11:25 PM
cwisenbaker06
Aug 19, 2015 04:29 PM
Civicircus
Aug 6, 2015 11:58 PM
Green02civic
Jul 27, 2015 10:48 PM
