Auto Transmission Rebuild (pics)
#151
Re: Auto Transmission Rebuild (pics)
#152
#153
Just finished my first rebuild on a 2002 Civic BMXA transmission and I'm hoping I didn't just make a fatal mistake. Everything went together perfectly however I listen to some advice from a friend and I sealed the case with hondabond. Now that it has dried I can see where if there was any excess that it's squeezed out of the case seam and, on the outside, it rubs off pretty easily. So I'm mortally worried that I'm going to have the same thing on the inside and some of these pieces are going to flake off and clog everything up.
So before I go to all the effort of putting this back into the car and then having an issue is there anyone that can confirm that was a big mistake and I should take it apart, strip all of the Honda bond, out and put in new gaskets and seal it up again.
#154
Unless you locked up a small person inside the case, no one is going to be rubbing in there.
If chunk did manage to get loose it will just get stuck in the filter, not going to damage anything
97-DX-Lover
06-14-2015 07:07 PM
MajTom
06-02-2015 12:48 PM
2001, 25430plr003, auto, bmxa, bxma, civic, description, honda, noise, parts, rebuild, screen, tranny, transmission, transomission
