Timing Belt DIY 2
Old Jun 22, 2014
  #211
drhawkinz's Avatar
drhawkinz has a spectacular aura aboutdrhawkinz has a spectacular aura about
Re: Timing Belt DIY 2
Originally Posted by mikey1
i have said it a thousand times.....i will never understand why people use torque wrenches on bolts this small, just go by feel, all they need is tight by hand and then a little snug with a wrench,
yeah i typically don't but thought it might be important to have proper torque specs since the gasket was in there. Luckily enough it was easy to get a vice grip on it and I got it back out in about 2 minutes.
on a side note.....i bought that exact same cast iron pipe you have except i got the 6 footer.....i agree its very handy, but i wouldnt recommend using a pipe extension like that with a ratchet, only with a breaker bar
yeah I had two 1/2" break bars. I tried it with a 3/8" ratchet and extension and it blew the ratchet apart but it was a craftsman so I just got another under warranty while I was at Sears getting the breaker bars.
Old Jun 22, 2014
  #212
A needle style torque wrench works better for lower torque. I stretched my bolts too when I tried to use the click style wrench...
Old Jun 28, 2014
  #213
drhawkinz's Avatar
finally finished the timing belt change today. Had to wait for a new lower timing cover and woodruff piece. As I was taking the harmonic balancer off I think the key feel into one of the holes in the control arm. So I'd recommend taping off the holes to avoid this bit of bad luck.
Other than that everything seemed to go back together twice as fast as it did coming apart. Car cranked up fine and seemed to to stay at the normal temp once it heated up. I guess we'll see over time if the workman ship holds up. Seems like a good idea to take the top cover off a few hundred miles to make sure the belt is wearing properly, which I guess would be no wear at all.
Excellent DIY!
Old Jun 29, 2014
  #214
mikey1's Avatar
yes, i believe it says in the manual to cover the holes with a rag to avoid doing what you did
Old Jun 29, 2014
  #215
drhawkinz's Avatar
SOB! hahaha, the first time I took it off it was fine then I put it back on to turn the motor to TDC and when I took off the balancer the 2nd time it took a dive.
Old Oct 29, 2014
  #216
Kirbert's Avatar
Kirbert is an unknown quantity at this point
I'm about seven years behind the curve on this -- and I haven't read all the messages in the meantime -- but I have a couple of things to add to the basic procedure described. First, it's important to note that, as opposed to earlier Honda models, the tensioner bearing has a built-in swivel so tightening the bolt down does NOT lock it in place. You can forget all the tightening-and-loosening steps that applied to earlier cars and are still carried over in the Haynes and Chiltons. Here's some better instructions for dealing with that tensioner:
* To get the old timing belt off, just reach in with a pair of needlenose pliers and pop that tensioner spring off its post. The belt will immediately go slack and can be removed.
* With the belt off and the spring off, install the new tensioner bearing, with locking pin in position, with the locking pin around the 4 o'clock position. With the bolt loose, rotate the assembly CCW until it hits something. Tighten the bolt down. Now, install the tensioner spring, being sure that the side of the plastic thing that says "Up" is up. Slide the belt on, making sure that the timing marks remain lined up at both crank and cam sprockets. Then just yank the pin, and belt tension is immediately applied. You're done. Time to start putting ancillaries back on.
Obviously, if you're reusing the old tensioner bearing, you'll need to fake that locking pin. A nail or stout piece of wire will do.
Old Oct 29, 2014
  #217
Kirbert's Avatar
As shown clearly in one of the photos in the original sticky post, the pivot bolt for the alternator CANNOT be removed. It runs into the structure of the car. It can be backed out far enough, though, that the alternator can be removed. Obviously, you need to remember to leave that bolt in the bracket as you remove the bracket from the engine, change the timing belt, and then put the bracket back in. If the bolt isn't in the bracket when it's reinstalled, it'll have to come back out!
Old Oct 29, 2014
  #218
Kirbert's Avatar
The procedure presented indicates that the alternator mount bracket should be removed before the upper and lower timing covers. This is incorrect, as the lower timing cover actually goes over the alternator mount bracket. The lower timing cover should come off first, then the alternator mount bracket.
Old Oct 29, 2014
  #219
mikey1's Avatar
sorry but this is horrible advice,
the tensioner bolt should not be tightened/torqued down until AFTER the belt is installed,
with the timing belt removed, and the grenade pin installed in the tensioner, you should tighten the tensioner bolt hand tight,
install the timing belt, then attach the tensioner spring to the post on the engine block (the tensioner bolt should still be loose at this point),
rotate the crank at least 2 revolutions and inspect the timing marks, if the marks line up this is the point when you torque down the tensioner bolt,
Old Nov 22, 2014
  #220
74project's Avatar
74project is an unknown quantity at this point
Great DIY! I followed this sticky while changing the timing belt on my 2005 Civic EX. For the most part, the procedure went quite easily. A couple of things that I did differently than the article was to install the motor mount bracket (5 mounting bolts) before installing the top timing belt cover. This bracket couldn't be installed if both the top cover and the bottom cover were installed. Also, before starting to remove the old belt, I marked a line with a silver Sharpee marker with a corresponding mark on the camshaft pulley itself.I did this on the crank pulley also. After removing the old belt, I transferred the marks from the old belt on to the new belt. When I went to install the new belt, it was obvious that the belt was in the exact same spot that the old one was. I double checked the timing marks on the pulleys were in the same spot as a sanity check.
Up to this point, everything went well. When I had the new timing belt on, I rotated the engine a few times counterclockwise back to TDC. The belt was tracking just fine and the timing marks lined up as expected. I was now at the step to torque the tensioner bolt to 33lb/ft. As soon as the bolt got to around 15lb/ft, I could feel the torque fall off. I kept tightening, and my suspicion was correct. The bolt had stripped! I pulled the bolt out and with it came the aluminum threads from the block. After researching on this site, it became apparent that this is a common problem with these motors. The engine has never been apart (109K miles), so I know that the bolt has never been over torqued, or cross threaded. I ordered the Timesert kit #1012 and waited the four days for it to arrive at my door. I followed the directions that came with the kit, and the insert went in without a hitch. I saw a lot of comments that blamed the last mechanic for incorrectly installing the tensioner bolt, but I'm thinking that this is a design flaw in the motor. A fastener that will be taken out a few times during the life of the motor, and it only lasts for one install of the bolt? I fault Honda for this design oversight. Looking at the history of the problem, Honda knew this was a problem long ago. There should of been an insert installed in this location from the start!
Old Nov 23, 2014
  #221
mikey1's Avatar
i would suspect you have a problem with your torque wrench, there is no way that bolt should strip after 15 pounds
Old Nov 25, 2014
  #222
Unless it was already on the verge of being stripped.
Old Dec 27, 2014
  #223
74project's Avatar
I'm sure that my wrench is accurate. It's a SnapOn model that's been calibrated by the airline I used to work for. I always back off of the wrench to the minimum setting after each use.
I initially installed the bolt hand tight and then used the torque wrench to get to the final torque. It was barely starting to tighten before I felt it give away and loosen again. This was way before I was even close to 33 ft/lbs. I removed the bolt and the pulled aluminum threads were on the bolt threads.
Old May 5, 2022
  #224
supersteve's Avatar
supersteve is a jewel in the roughsupersteve is a jewel in the roughsupersteve is a jewel in the rough
this is why you NEVER TURN the timing belt using the cam, you should always turn it using the drive pulley which is the crank,
if you have the crank pulley removed and need to turn it, just temporarily install the pulley with the key and use the crank holding tool to turn the crank,
just re torque the cam bolt to spec, and throw a bit of locktite on there while your at it
Just bought an 04 EX and researching how to perform this timing belt job and found this thread. I'm surprised no one else pointed this out. Lots of inconsistent info out there, from A1 auto's youtube video turning it clockwise to this using the cam to set TDC.
Old Jun 3, 2023
  #225
Re: Timing Belt Tensioner Bolt upgrade...
what type of torque wrench are you using?
I twisted my water pump bolts because I was using a higher end torque wrench, click type. The ones that uses the click, they need to be chosen by torque range. The regular bigger ones does not have enough sensitivity for low torque.
I had to use a needle beam type for lower torque bolts.
https://www.homedepot.com/p/GEARWREN...957N/313870121
Don't use a gun to shoot down a mosquito
EdGasket
May 25, 2015 01:06 PM
dosmastr
May 5, 2015 12:19 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
bsmiley
Apr 27, 2015 01:27 PM
CivicVoz
Apr 16, 2015 08:07 PM
