Evaporator Replacement
Old Nov 14, 2012
pdqtimetrialer's Avatar
pdqtimetrialer is an unknown quantity at this point
Most of the AC components on a 2002 Civic are relatively easy to access - compressor, drier, condensor.
Turns out, gaining access to the evaporator isn't too bad, once you've learned the hundred ways not to do it. It looked it was going to be a pain to replace and I was thinking of skipping it, except that the threads for the line to the evaporator had gotten galled up.
Name:	goobered threads.jpg
Once I got the hose assembly removed at the firewall, it became obvious where the leak was. Good thing I decided to change the hose and evaporator after all!
Name:	leak at firewall.jpg
  • Remove glove box
  • Remove bottom plastic kick shield
  • Remove the kick shield panel on the passenger side.
  • Remove the blower motor.
Name:	blower housing.jpg
Name:	blower housing front.jpg
  • Remove the metal bracket that stiffens the dash board at the bottom of the glove box.
  • Disconnect all the harness plugs going into the ECM module, and disconnect the large harness connecting the engine harness to the interior harness
  • Remove the ECM module. This will take a long set of extensions. You'll also need a 10mm deep well socket.
  • Remove the bolts holding the blower module. I think there are 5 of them. One hidden behind the dash at the lower left; one way up top on the right hand side, one at the bottom middle that is actually accessible, one that bridges a bracket to the ECM module and holds the harness and the last one really deep straight in just right of the ECM module.
Name:	bracket for ECM.jpg
  • Remove the plastic cover for the evaporator core
  • Remove the hose assembly at the firewall if you haven't already.
  • Slide out the evaporator and the expansion valve assembly
Name:	install evaporator and expansion valve.jpg
ID:	84288A few notes on reassembly.
  • It was really hard to push the hoses in to the expansion valve. To get it started, I first assembled the connection with a M6 x 40mm long bolt, then I took that bolt and used a M6 x 30mm to make the final connection. I didn't trust the limited threads of the stock bolt.
  • Make sure to connect the harness to the blower control unit before the ECM module and everything else is installed.
Old Jul 8, 2023
alice_keda's Avatar
alice_keda is an unknown quantity at this point
Re: Evaporator Replacement
Mini spray dryer machine
BlueEM2
Engine DIY
285
Sep 19, 2023 09:35 AM
Gunner
Engine DIY
Apr 25, 2021 11:31 AM
BobDobolina
Electrical DIY
Apr 16, 2018 01:59 PM
brobo
7th Gen Do It Yourself Articles
45
Jun 16, 2015 01:15 PM
brobo
Transmission DIY
Dec 31, 2010 12:12 PM
