Starting issue
Old Jul 3, 2019
Tracecross30's Avatar
Tracecross30 is an unknown quantity at this point
Starting issue
Ok so to all those whom having issues with their car start only with cable from the scanner connect to it,here's the problem that causing it. The ground wires need to be check before you do anything or waste money taking it to the mechanic. I took a picture to show. The two from the water passage on the thermostat housing and the one to the far left by transmission hook where my finger is pointing at.
The two at the water passage, the one to the left where my finger not actually touching the bolt at the water passage, that one was loose so I tightened it and the car starts right up.
Old Jul 4, 2019
Re: Starting issue
thank you!
We always appreciate good input!
Old Jul 4, 2019
Re: Starting issue
Yeah, you welcome.
Old Jul 4, 2019
Slumpertcivic's Avatar
Re: Starting issue
I suggested you check that 2 weeks ago.
Originally Posted by Slumpertcivic
Also the two sets of engine harness ground connections at the thermostat can cause similar issue if they are grungy/loose
We are starting to cross over from DIY to Keep It Alive at these cars age.
Old Jul 4, 2019
Re: Starting issue
Oh ok.
123abc
May 14, 2019 08:31 AM
smann2
Mar 1, 2019 03:33 AM
com10goat
Jun 11, 2018 12:22 PM
AMatterOfPride
18
Oct 21, 2012 07:34 PM
dbcivickid
Detailing
35
Mar 1, 2004 01:42 AM
