DIY cluster swap 2003 - 2004 dx also available for other models
#211
Re: DIY cluster swap 2003 - 2004 dx also available for other models
I'm would like to swap my cluster 01 to hybrid cluster if who can do ti please help me please TAWEEKIAT-B@hotmail.com I'm need the hybrid wiring diagrams
#212
Hello, Im succesful on doing a cluster swap from an 05 to my 02. Although, when I first fired up the cluster, my SRS was off. Few minutes later, it's stuck on. I've tried resetting it to no avail. I've tried checking if there is a SRS code to no avail. Everything works except the SRS light is stuck on. Any ideas? Anything would helpful. Thank you. I double check pin 8-9 in the green plug and they're connected correctly.
#213
Received 1,148 Likes
Rep Power: 485 Re: DIY cluster swap 2003 - 2004 dx also available for other models
Check if there's an srs light condition? Driver's side seatbelt is a common one in 7thgens
#214
I've tried pulling the srs code and to no avail. I'm starting to see that the fuel gauge is also stuck on full. My hunch is that the cluster is broken as I picked it up from the salvage yard and the car is totalled. What do you guys think?
#215
Super Moderator
Received 1,853 Likes
Rep Power: 196 Re: DIY cluster swap 2003 - 2004 dx also available for other models
I would recheck all your wiring, always possible you mixed a few up.
#216
I have double checked it a dozen of times. The fuel gauge finally moved, I'm probably not used to how much kilometers I need to run before it moves from full. Though SRS Light is still on. when I picked up the cluster, I cut the wiring harness from the car I took the cluster from so I can physically check it as well. So far, it matches.
#217
My 02 Honda Civic have 2 pink wires, one from the Blue Plug(SRS wire) and one from the Green Plug(Canada Windshield Washer Sensor). Because they were both the same colour, I mixed them up. I just had to switch around my modified wiring harness on the Green Plug from Pin 1 to Pin 9 vice versa and it worked after resetting the light. No more annoying lights.
I was actually reading up on some of the thread about cluster swap and they have also rimmed on the same SRS issue I rimmed with but didn't see the answer, I just remembered that I might have mixed the pink wires up.
Also Fuel gauge also works well, just not used to it yet.
#218
Rep Power: 0 Re: DIY cluster swap 2003 - 2004 dx also available for other models
Hi all!
My GF's 2004 Honda Civic DX from Canada is now having issues with her cluster too. It occasionally dies, every needles goes to 0 and starts working again.
Current cluster:
HR 0279 572
78100-S5A D160
Thinking of replacing her cluster with: 2003 Honda Civic Automatic Speedo Instrument Cluster 78100-S5P-C540 (shown below)
Do I need to rewire or is it plug and play?
Current cluster:
HR 0279 572
78100-S5A D160
#219
Hi all!
Current cluster:
HR 0279 572
78100-S5A D160
Current cluster:
HR 0279 572
78100-S5A D160
#220
Received 1,126 Likes
Rep Power: 191 Re: DIY cluster swap 2003 - 2004 dx also available for other models
Is the orange illumination wire hooked up to the aftermarket deck?
#221
yep, you'll have to re-pin the connectors.
#223
Thanks everyone. Everything works well. Spliced up ABS and grounded it to turn off the ABS light.
Any idea why the high beam indicator light is on even when the car is turned off? Fixed Blue plug instead of Pin #9 moved to Pin #1
#224
Super Moderator
Is the red/yellow wire in pin 10 on the blue connector. This is the wire that controls the high beam indicator.
#225
The following users liked this post:
Sean Anderson (01-21-2021)
#227
Super Moderator
It is possible but some of the gauges won't be used.
https://www.civicforums.com/forums/2...civic-em2.html
rockhound124
02-24-2020 09:05 AM
aznrice
04-07-2004 11:56 PM
hi2nr
04-07-2004 11:39 PM
