DIY: Grounding kit Install
Old Nov 10, 2003
  #211
jblayz1's Avatar
jblayz1 is an unknown quantity at this point
Originally posted by happies713
QUESTION!! my kits are 38. bucks shipped. if you subtratct shipping thats 30.00 bucks a kit. its a good deal think aobut it, and quality assured!! over 100 kits sold!!
$8 for shipping??? Express Mail?
i put a Neuspeed sticker on my car and noticed 2-3hp gains and and stiffer suspension!!!!!
woohoo!
Old Nov 11, 2003
  #212
Joey_Zazza's Avatar
Joey_Zazza is an unknown quantity at this point
Exclamation Addy
hey bud, can u email me @ snakeeyes_modz@yahoo.com, im interested in buying the grounding cables from u, thanx
Old Nov 11, 2003
  #213
civicvtec1ps's Avatar
Search and Learn
woohoo!
He ship it out through USPS. Takes couple days only. Wires are pretty heavy, cost at least $5 to ship it out.
You better off email him first. Happies doesnt check site often..
Old Nov 25, 2003
  #214
IllusiveImports's Avatar
IllusiveImports is an unknown quantity at this point
not to rag on the position of the wiring, but in import tuner they say to never ground the valve cover, and all their tests show that when they do ground it they lose hp.
Old Nov 25, 2003
  #215
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
he puts the wires in a REALLY small box though; i couldnt stuff them in there again. Haven't had a chance to install them, but im going to take pictures of my headlight beam on my wall before and after, so i'll hopefully get some quantitative results of these.
Old Nov 26, 2003
  #216
I'll take some pics as well. Oh and I did notice an improvement when grounding the valve cover. Definately a difference when compared to no grounding. I've tried both ways. The engine even sounds a bit better--like it's not struggling as much. Smoother.
Old Nov 26, 2003
  #217
jwalker87's Avatar
Bodacious Member
mmm...cant wait to get my car back so i can put this baby on! the shop said it might be ready today...
Old Dec 1, 2003
  #218
shmeb's Avatar
shmeb is an unknown quantity at this point
Just saw this thread now and for what it's worth, I agree completely with opto_isolator about the possible negative effects of adding more ground wires (his comments were around pages 3-7). I'm an electrical engineer also, and I've taken courses on grounding for the radio equipment I work with (public safety radios - ie police walkie-talkies). By chaining a lot of parts of the car together, rather than making a central point the ground, you can have ground loops which will not benefit the car at all and could possibly damage components or make them less effective. I'm not saying that it won't help, I'm just saying that it could hurt.
Old Dec 2, 2003
  #219
Some cars offer a grounding kit as a factory upgrade, so I'm sure they do help. I would think that a ground wire attached to a part in the car will help it function better. Can you explain some more about why daisy chaining will cause problems? I felt like it helped with the stereo at least.
Old Dec 3, 2003
  #220
jwalker87's Avatar
Bodacious Member
i think the general rule is that you have to be reasonable. yes, more grounding points with less resistance will improve your performance; but just as you have have too few grounding wires, you can also have too many, creating the grounding loops (i think that is the negative current going through one of your grounding wires, then back through another, which is bad). Just because more is good doesn't mean even more is better.
Old Dec 16, 2003
  #221
xmeeksx's Avatar
xmeeksx is an unknown quantity at this point
i didnt notice any difference when i installed this. maybe im just not paying attention but everything seemed the same. my car still starts exactly as it did before, my stereo sounds the same, and well i cant really tell if it got faster or not. i am not bashing the product, just saying my opinion about it. i will try other grounding points when it gets a little warmer and see if it makes any difference
Old Dec 16, 2003
  #222
I used the same grounding points that Happies suggested. I also have the ignition coils grounded like futurersxswap did. I'll take a pic and post here. My cables are all black, except for the smaller ones on the coils that are silver.
-----> I noticed that the car ran a bit smoother with some more pickup when you first accelerate. Stereo may have improved.
IMPORTANT!! Did you sand down the spots where you attached the cables? You need the cables touching BARE metal, and not painted metal. That could make a difference.
Old Dec 16, 2003
  #223
jwalker87's Avatar
Bodacious Member
i just installed mine; and noticed a nice difference. Starts up a little better, and I noticed the most improvements in the headlight brightness and throttle response. Throttle response was greatly increased, and i think it has a bit more power. Didn't notice a big improvement in stereo, but hey.
WARNING: BE CAREFUL WITH THE WIRE FROM THE FIREWALL TO THE STRUT TOWER!!! The first time I put it on I accidentally layed it right across the Throttle! This is bad! If i gunned it at all it stayed gunned for like 5 seconds! Use twist ties to secure the cables!
Old Dec 17, 2003
  #224
I didn't think of that. But the cables are right in back there. I better go check mine tomorrow. But seriously, this is one of those mods where you spent money and want to convince yourself that it works.If someone installed it one night and I drove it the next day, I probably would not have noticed any difference.
Old Dec 20, 2003
  #225
xmeeksx's Avatar
i switched one of my points from the battery to another spot on the engine block..i had engine whine for a while until i switched it from somewhere near the altnernator to a better spot on the engine block
Old Dec 24, 2003
  #226
g33s0n6656's Avatar
g33s0n6656 is an unknown quantity at this point
My friend just bought on 04 subaru wrx and did a grounding kit on his own with cables and gold plated connectors he bought from auto sound and effects for about 30 bucks ( places will flex on the price for the gold plated connectors be persistent) he used the central grounding point method and noticed better engine running and much stonger starts in cold weather considering he has to turn over a turbo this is an excellent thread big props to whom started it i cant remember after reaading a cajillion,million responses thanks to all ill be doing this in the next couple of days to my 03 ex sedan im going to look into making a central grounding plate at my work solid copper about 3/8 inches thick ill get a pic up if i decide to do so
Old Dec 25, 2003
  #227
synikal's Avatar
synikal is an unknown quantity at this point
after reading all of the posts, it seems like everyone is just like "I THINK it works" or "it MIGHT have given me more power" or "it helped me A LITTLE in response". But, for as cheap as the mod is, I wouldnt definately buy it just for the fact that it looks good under the hood.
Old Jan 2, 2004
  #228
I think this would help more if the factory grounding had problems. You would notice more of a difference.
Old Jan 2, 2004
  #229
CelCUs's Avatar
CelCUs is an unknown quantity at this point
Only difference i noticed was smoother shifts on my Auto, headlights seem a little brighter (only i can notice it) and it starts a lil' better.
I'd still recommend getting the grounding kit.
Old Jan 9, 2004
  #230
draganjr's Avatar
draganjr is an unknown quantity at this point
are the ground wires still for sale??? thanks
draganjr@msn.com
Old Jan 9, 2004
  #231
I would look up the e-mail of the guy who first posted this thread and ask him. I doubt he'll get back to you, since the thread is so old. I think he's still selling.
Old Jan 9, 2004
  #232
draganjr's Avatar
thanks, i emailed him.
Old Jan 9, 2004
  #233
liljoe's Avatar
liljoe is an unknown quantity at this point
email chris@carbonation.com
he sells ground kits as well, really nice.
Old Jan 9, 2004
  #234
joedc5's Avatar
joedc5 is an unknown quantity at this point
Hey what do I do?? My battery is relocated in the Trunk! Do they make a kit for that?
Old Jan 10, 2004
  #235
Not that I know of. You need to go to an audio shop, get some long lengths of wire, and make a kit yourself. Gold plated ring terminals can be found at autozone.
Old Jan 10, 2004
  #236
joedc5's Avatar
Thanks.
Old Jan 14, 2004
  #237
donesixer's Avatar
donesixer is an unknown quantity at this point
I'm LilJoe's buddy. I have also started selling a ground kit and have installed on a number of cars (BMW, Honda/Acura, VW) with very good returns.
My kits are installed as a "parallel" setup and is a little more comprehensive.
Both kits include a machined aluminum block that shows no bolts or connections when installed. Very clean.
The Base Kit has the block, fasteners, bracket and illustrated instructions to show you the best connection points for the most performance. This is set at CDN$49. Good for the DIYers.
The Full Kit adds the cabling (both 4 and 8 Guage, which should be noted, this is big), gold connectors, battery terminal and illustrated instructions.
This is set at CDN$119
I should mention something as well. It would appear that not one person has connected the most important ground.
The correct grounding will make the charging system more efficient, making the alternator draw on the crank less. It will also bring all sensors "in line' by providing the same source voltage.
My clients have shown significant returns through increased mileage and performance.
Now, lets see if these pics work...
Chris
Old Jan 14, 2004
  #238
So are you gonna tell us which point we're not grounding, or do we have to buy your kit? I have a feeling it's something to the alternator.
Your kit is actually a good idea. I already bought the wire kit from Happies and might give your base kit a try. You have any pics installed? I wanna know where that box could go. Another thing--I guess your box accepts five wires and has one single wire coming out the back for a central ground point?
Old Jan 14, 2004
  #239
donesixer's Avatar
Well, the alternator is one connection, but not the one I was referring to.
The block has five ports in the front for the 8AWG cabling around the engine bay.
There are also two ports for the 4AWG to the battery and the body. You just can't see the second one.
If you're going to use the Base kit with Happies kit, let me know, I can modify the block to accept 4AWG off the front as well.
You can install this anywhere. Most popular has been passenger side engine bay, and should be close to the battery.
Old Jan 14, 2004
  #240
Entropy's Avatar
Entropy is an unknown quantity at this point
This is just a guess, but you probably have to drill to install that block, right?
