DIY: Grounding kit Install
Old Aug 5, 2003
  #181
nymbus2k's Avatar
nymbus2k is an unknown quantity at this point
the junction box aka central grounding point is used so the negative terminal won't be overcrowded with wires ..
here's a pic of a car with the kit installed .. the juction box is the pic on the right:
Old Aug 5, 2003
  #182
slamtank's Avatar
slamtank is an unknown quantity at this point
wow wow..where did u get that bracket?
i mean that gold or copper piece on the juction box..
is preventing the negative terminal to be overcrowded just for a looks or does it do something better?
Old Aug 5, 2003
  #183
aznrj's Avatar
aznrj is an unknown quantity at this point
i want those..
Old Aug 5, 2003
  #184
sepudo's Avatar
sepudo is an unknown quantity at this point
nymbus2k:
thanks for commenting about my setup.
how are those grounding points holding out for you?
I would suggest grounding your driver side tower to the junction instead of the firewall, remember, path of least resistance...
just a thought.
Also, your 0-60 numbers are very realistic, although I haven't clocked myself, I too noticed a differerence after reseting the ecu and driving around for a while.
By far the most productive DIY - cost to benefit ratio
Old Aug 5, 2003
  #185
nymbus2k's Avatar
slamtank: the junction box is just an aluminum triangle with predrilled/threaded holes for one side of the ground wire to bolt onto
sepudo: the kit did not come with a wire/cable long enough to travel from my positioned junction box to the driver's side strut .. the only location i had for the juction box was just below the fuse box .. i will try to get pix up soon to help my statements
Old Aug 5, 2003
  #186
nymbus2k's Avatar
here are some pix i took just minutes ago with the arospeed ground wire kit installed:
front view:
juction box (central ground point):
side view:
close up view of engine, front rad. sup. and negative terminal to junction box:
Old Aug 5, 2003
  #187
Derek-CEO's Avatar
Derek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz ErthangDerek-CEO Ownz Erthang
added to DIY section
Old Aug 5, 2003
  #188
aznrj's Avatar
wont your engine bay look all wire-messy w/ all those wires after install.
Old Aug 6, 2003
  #189
slamtank's Avatar
where did u get that redish purple thing? is it called bracket? whatever..where did u get it?
Old Aug 6, 2003
  #190
PaCiFiKbAllA's Avatar
PaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond repute
dude that is exactly what i wanna know...where did u get that so called "junction box" and how did u bolt it to the fender wall? i read all these posts about the grounding kit and i must admit, we have some smart 7th gen drivers....all u tech headz i give u propz! I might order a set from happies and choose a whole new pattern of grounding points...just to see if there is a difference from the way all uv yall are doin' it....i do like the way you made yours tho nymbus2k....much props!
Old Aug 6, 2003
  #191
happies713's Avatar
happies713 is an unknown quantity at this point
My kit only has two wires going form the negative terminal.
That red kit looks over croweded, its nice!
but my kit is a simple 5 wire, Dasiy Chain method, much cleaner, and simpler looking, but still very effective in provind you with a smoother idle, increased throttle response, brighter head lights, increased stereo efficency. =)
Old Aug 6, 2003
  #192
civicvtec1ps's Avatar
Search and Learn
Old Aug 6, 2003
  #193
nymbus2k's Avatar
the junction box came with the arospeed ground wire kit:
i used the hole that bolted a mount for the fuse box to bolt the junction box .. but the bolt that was on the mount was too small and narrow for the juction box ... so i made the hole larger and used the supplied bolt and nut to secure the juction box into place
Old Aug 6, 2003
  #194
cdmx's Avatar
Originally posted by civicvtec1ps
oh badassss....so did you notice anything from that setup?? Take out all those wires and test the car, put them back on and test...it looks good for just looks anyway!
Old Aug 6, 2003
  #195
Search and Learn
its acutally my friends car. he LOVES it. def recommanded
Old Aug 7, 2003
  #196
slamtank's Avatar
wow..but can we just put one wire that goes to the silver bolt right above the third coil bolt? which one will be better?
Old Aug 8, 2003
  #197
Grey's Avatar
DIY King
That's what I'm wondering myself... It's hard to get those wires to contact the little bolts on those ignition coils. If you've ever taken those nuts off you'll know what I mean. Plus the valve cover is magnesium and those bolts are imbedded in it. Magnesium has a relative electrical conductivity of 0.42, while aluminum has a relative electrical conductivity of 1.00. I would ground the two bolts that hold the valve cover on. Those probably go all the way through the valve cover and touch the block. Then again, maybe both would be good?
Old Aug 8, 2003
  #198
ALPHSTER's Avatar
THE FIRST LETTER!
ALPHSTER has disabled reputation
Has anyone noticed when you shut the car off with the grounding kits the tach and speedo needles jump a little?
Old Aug 11, 2003
  #199
happies713's Avatar
Having my kit on my Honda Civic LX, the car i have not noticed the speedo jumping.
Old Aug 12, 2003
  #200
YS's Avatar
YS
YS is an unknown quantity at this point
me too
Old Aug 12, 2003
  #201
2k1civicExCoupe's Avatar
2k1civicExCoupe is an unknown quantity at this point
I made my own kit(sorry Happies) but i have all of the points installed except the 2 where the radiator support is. the nut WILL NOT come off. i tried everything and pretty much all possibilities. can anyone help me. o yea, i did feel smoother shifts, brighter lights, and louder stereo. PLEEEAASSEEE HELP!
Old Aug 18, 2003
  #202
cdmx's Avatar
um try a longer breaker bar...i dont see why it would be so hard to get off...see if they might have welded it by mistake. only other thing i can think of is to liberally soak it with WD-40
Old Aug 18, 2003
  #203
cdmx's Avatar
This is just an update on my earlier post...I finally recieved the gold ring terminals...there must have been something wrong with shipping...he finally sent the package with priority mail and i received them. he sent me like alot more than i ordered. I highly reccomend.
that looks bad a$s.......
GUYS i just found a place that sells the GOLD RING TERMINALS for $.49 cents...they are on sale right now. Here you go
http://www.audiotronicsaccessories.c...2002/inac.html
(BUt theres a catch, you have to email him about it because they have an error with shipping...shipping is only $2.00 when it comes up 13 for shipping online. He asks me to send a money order but im asking him about a credit card payment.)
Here is what i bought:
11 feet 4 Gauge black/clear 2058 strand OFC wire. $15.89
8 -4 awg 5/16 stud Gold ring terminals $5.92
2 gold Battery terminals inputs for (1) 0 (1) 4 and (2) 8 gauge power wires $29.30
hehe so i spent 51.11
This is an update on those gold ring terminals i bought....WELL i have not recieved them and i was supposed to a week ago, the guy even offered to overnight ship another set BUT i have not recieved those either. I have requested a refund
Old Sep 11, 2003
  #204
yellowcoppy95's Avatar
yellowcoppy95 is an unknown quantity at this point
i would like to know if anybody out there that has bought the kit (or something similar to it) has found any other/better grounding points?
Old Sep 13, 2003
  #205
I bought it, but the grounding points given are already good. The biggest gains I noticed were better cold starting and improved stereo performance.
Old Sep 13, 2003
  #206
reloaded's Avatar
reloaded is an unknown quantity at this point
grounding wires
Circular Grounding System - By utilizing a 24 karat gold plated distribution block and multiple grounding points, improved idle and drivability are often obtained as the additional grounding points equalize resistance and voltage between various ground points. Each 8 gauge spiral twined cable is wrapped with signature HKS purple plastic to protect and add color to the Circle Earth System. Vehicle specific kits included pre-measured cable lengths and distribution blocks.
kinda pricy
http://www.modacar.com/products/Honda/Civic/GROUNDK/
Old Sep 13, 2003
  #207
Mr.Modify's Avatar
damm that's alot for a grounding kit!!! I was gonna get this "platinum" one that this shop in Houston Manufacturers but i doubt it's real platinum or anything !! besides there selling it for 75 bux some i like what the hell...
Old Sep 13, 2003
  #208
cdmx's Avatar
i found out if you have better spark plugs you might not notice a difference with anything but stereo sound (mabye)
Old Oct 10, 2003
  #209
Search and Learn
heres mine
Old Oct 11, 2003
  #210
dragoon's Avatar
Damn, another mess of wires going into my engine bay (after HID kit)
