Fast Blinker (Not Bulb)
Old Aug 25, 2020
jledford's Avatar
jledford is an unknown quantity at this point
Recently I've had an issue with my 2005 Civic EX SE where the front driver's side blinker doesn't blink and the rear will blink rapidly. I changed the bulb and it still doesn't work. I thought possibly it could be a relay, but I'm not sure. And, what I really don't understand is that if I lock the car with my key fob, all the lights, including the front driver's side, lights up correctly. Also, when I press the yield flashers all the blinkers work except the front left. I know basic electrical, but it's definitely not my specialty. I have had LED headlights that I installed over a year ago, and haven't had any issues at all with them or the blinkers. The passenger side blinker works perfectly. Any help would be greatly appreciated. Thanks
Old Aug 25, 2020
Re: Fast Blinker (Not Bulb)
The parking lights are flashed by the keyless module, not turn signals.
the bulb in question is a dual filament bulb. Could the bulb socket have problems? Can you swap it with the other side that still works?
Old Aug 29, 2020
jledford's Avatar
Yes! Swapped them, and, what do you know the problem switched sides so I know that the socket is the problem. Hard to tell with the socket because it didn't show any signs of corrosion or anything. I ordered a replacement for about 10$ on Amazon so it'll be an easy fix. Thank you ezone!
Mani2402
Electronics
Dec 14, 2019 11:36 PM
onedr
May 30, 2014 01:16 PM
SlimRisk
Feb 29, 2012 02:46 PM
seelsy
May 23, 2007 11:59 PM
civic12
Jul 24, 2003 11:40 PM
